Skidded coils
Discussion in 'Flatbed Trucking Forum' started by W Bench Farms, Dec 1, 2020.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    Looking for some info on securement and tarping on skidded coils. Have been seeing some close to home loads on these, and have never hauled any. Thought I'd get a little overview before I went too far into it. I would imagine these are mini coils.
  3. PoleCrusher
    PoleCrusher Road Train Member
    7,503
    82,194
    Aug 26, 2014
    LLMF
    Secure with straps or chains, crossed and use proper edge protection. Don't be lazy, cross strap each coil or stack. I prefer straps on skidded coils. 4' drop tarps with padding.
    Here is one we did recently...
  4. Espressolane
    18,648
    116,821
    Skidded coils can be done a few different ways
    It all depends on how they are set.
    With out better information it’s difficult to provide some ideas.
    @PoleCrusher has a good photo of one method posted above. This is the basic idea for most situations.
  5. jamespmack
    216,477
    I dont strap then. But others do. Rubber under the front stack, X chains with edge protectors. Single chain on anyone behind the X as long as it covers weight. If you space them out, another X chain. You should X chain back stack, this I do and dont do just depends. If you have a tall stack it gets X. If the require they get 3. I tarp the lazy way.
  6. cke
    cke Road Train Member
    6,125
    75,440
    Aug 4, 2013
    Colfax Wi
    No wonder you don’t get nothin done. Using all that securement like that.
  7. jamespmack
    216,477
    Only somedays I'm half fast, others I'm half ...ed.
  8. HillbillyDeluxeTruck
    5,951
    30,428
    Mar 3, 2013
    San Antone
    These are 6 4ft x 4ft coils. I cross chain the front coil, then strap the other 5. I thought I had a pic of just the coils but I couldn't find it on my phone.
    Bean Jr., cke, jamespmack and 2 others Thank this.
  9. W Bench Farms
    211
    351
    Oct 16, 2017
    Thank you for all of the replies. That's what my idea on securement was, but just wanted to double check.
    Any issues with the straps or chains sliding off the coils on top? I know these are larger diameter, but if you try to strap across the top of an upright barrel, the straps always want to slide off.
    cke and jamespmack Thank this.
  10. jamespmack
    216,477
    Don't haul them cheap, as in drive the rate down using the "backhaul" term.
    Its not black iron, it finished, or semi finished product. Charge a proper rate.
  11. cke
    6,125
    75,440
    Aug 4, 2013
    Colfax Wi
    Use something other than plastic strap protectors, too slippery. Use carpet or rubber protectors. Be very precise with strap or chain placement so they won’t slide off the coil
