Slack adjuster adjustment
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Daycabinit, Jul 14, 2021.
  1. Daycabinit
    Daycabinit Light Load Member
    93
    60
    Dec 11, 2016
    Never had a trailer with this type of nut on slack adjuster. How should this be adjusted?
  3. AModelCat
    164,186
    That's not the adjuster. That just sets the point where the ratchet mechanism in the adjuster tightens it up. The actual adjuster is on the body of the slack adjuster just like every other one.
    Worst thing to do is manually adjust an auto slack. Wears out the ratchet mechanism prematurely.
  4. Daycabinit
    93
    60
    Dec 11, 2016
    That axle keeps locking up if I move that nut one way or the other will it not auto adjust so tight?
    Rideandrepair Thanks this.
  5. Shawn2130
    Shawn2130 Heavy Load Member
    896
    1,897
    Sep 20, 2015
    Southern Ontario
    Could also be its time for brake inspection for that wheel.
    There’s a weld strip on the end of the cam that causes that set of brake to brake harder if the driver can notice.
    Sometimes a slack adjuster can auto adjust too tight, but I notice that more when brake pads are new and breaking in.
  6. AModelCat
    164,186
    Tight or loose adjustment has little to no bearing on braking force. All it does is change the amount of brake lag. The brake chamber puts out a constant force per PSI of pressure over the length of its stroke.
  7. Big Road Skateboard
    7,033
    39,806
    May 2, 2021
    No it will not auto adjust. That needs to be set to manufacturer specs, as does brake chamber rod length, and slack adjuster length from center of cam to pin.
    Lot more to proper brake operation with that style auto adjuster than "set it and forget it"
    Rideandrepair and Daycabinit Thank this.
  8. Rideandrepair
    17,530
    56,810
    Aug 8, 2015
    Won’t hurt to adjust them. The adjuster bolt is on the slack, it doesn’t have a lock button, like others. Just one bolt, no spring loaded lock nothing, just a ratchet effect. Tighten it up, hear it ratchet. Backing it off, there’s much more resistance, hear it Ratchet much louder. Sounds like your tearing something up. Don’t worry, just crank on it. Won’t hurt anything. Tighten it up, back off 1/2”. I’d check ride height. If it’s too high, brakes will lock up very easily. Air ride, rear axle usually locks first. Usually noticed when empty. Especially in rain and snow. Yeehaw!!!
    Daycabinit Thanks this.
  9. Rideandrepair
    17,530
    56,810
    Aug 8, 2015
    That bolt you show a pic of is set when the slack adjuster is installed. Leave it alone. If you want to check the automatic operation of a slack, after you adjust it, back it off a bit, 1/4-1/2 turn, leave the box end of the wrench on the adjuster bolt, note the position, say 3 O’clock. then go pump the brakes. The adjuster bolt should tighten itself, back to a safe position. Always have parking brakes released, wheels chocked when adjusting brakes. Having a helper pump the brakes helps a lot. You can watch the bolt tighten one click at a time with each application of foot valve.
    Daycabinit and Short Fuse EOD Thank this.
