Slack adjusters
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Xyrex, Apr 23, 2023.
  1. Xyrex
    Xyrex Bobtail Member
    15
    6
    Nov 27, 2020
    How can one tell if a meritor slack adjuster is no good? Other than the obvious brakes out of adjustment sign.
    On the bendix ones it should click when backing off correct?
  3. Big Road Skateboard
    7,080
    40,122
    May 2, 2021
    Be easier to just go to Meritors website. They usually have tech info downloadable.
    For the most part, if you can tighten, but not back off, release the pawl and back off, your good.
    That doesn't necessarily mean it's doing it's job though. Other factors can influence it's operation
    Oxbow Thanks this.
  4. Xyrex
    15
    6
    Nov 27, 2020
    I tried to find the manual can't find one. Pls what other factors can effect the operation of slack adjuster?
  5. JB7
    JB7 Road Train Member
    1,006
    1,781
    Dec 13, 2022
    Laurel, MD
    Literature on Demand - Product, Technical & Training Information | Meritor
    Clevis pins should not be frozen or have excessive play. Slack adjuster greased at regular intervals. S cam bushings and brakes should be in good condition. Literature on Demand is free.
    beastr123 and Big Road Skateboard Thank this.
  6. Artur 1996
    Artur 1996 Bobtail Member
    5
    I would recommend you look online Volvo repair manuals.
    My friend managed to solve his problems, there was the necessary information.
  7. Rideandrepair
    17,548
    56,858
    Aug 8, 2015
    The ones with the button type pawl can be bad. The adjuster strips out, or dried grease makes them not function properly. The whole adjuster can be taken out, cleaned, replaced if needed.
    BoxCarKidd Thanks this.
