Sleeper cab, no power
Discussion in 'Ask An Owner Operator' started by Singh11, Jul 9, 2021.
  1. Singh11
    Singh11 Bobtail Member
    8
    4
    Oct 6, 2019
    Hello everyone, I have a problem with my truck. It is 2013 Freightliner cascadia. The sleeper lights are not working and sleeper hvac also not working. LWR lamp is working (the small sleeper light) and the music mute switch still working, also the power outlets are working fine. Just the rear hvac and and the dome lights are not working. Dome lights from front dash doesn't work either. If I press the sleeper button to make the temperature settings same for front and rear, the light turns on and goes off in a sec.
    I checked all the fuses behind the glove box, engine bay, the big ones near firewall as well. No problem there. I searched online and found out that low voltage disconnect can cause this but I could not find where it is located or if there is one at all on these trucks, maybe controlled by the computer. Any would be appreciated. Thanks
  3. TruthfulGeist
    TruthfulGeist Bobtail Member
    25
    22
    Nov 6, 2016
    I’m not sure about that truck but my truck has a fuse box under the bed it is a pro star the box is located in my driver side rear sleeper box door. It doesn’t sound like a fuse considering it comes on and then goes off my pro star has software to diagnose things like that. Yours might also but i’m thinking the switch upfront might be your issue my truck has a button up front to kill the lights in the back but the HVAC I’m not sure mine went out and I discovered I had unplugged it a little bit while putting some straps in the passenger rear sleeper box door simple fix plugged it in and good to go. Good luck and before you take it somewhere take advantage of capitalism and call around to find the best price at the best place with the best reputation
    Singh11 and Doealex Thank this.
  4. Spyro2112
    Spyro2112 Medium Load Member
    622
    432
    Mar 17, 2018
    Jumper wire from battery terminal fuse box. 4 of them jupe one to another till power
  5. bzinger
    bzinger Road Train Member
    16,646
    66,144
    Dec 10, 2014
    omaha , ne
    As I learned today on my 2013 cascadia that was having similar issues there is module behind the panel that has the 4 way flasher switch , floor light switch and the dash dimmer switch on it .
    It controls all the switches, lights inside and out and the steering wheel switches.
    When it goes bad crazy things start to happen ......with mine all the exterior lights came on without the switch on .
    Signal lights quit.
    All interior lights quit except the 2 above the seats .
    Cruise quit .
    Jake quit .
    Flashers quit .
    Switch panel in the sleeper quit .
    Freightliner in Neosho Missouri fixed it today for 391.00.
    Singh11, Pittstruck and Speed_Drums Thank this.
  6. Speed_Drums
    Speed_Drums Road Train Member
    1,029
    1,989
    Dec 26, 2014
    I was going to post what you wrote in your thread. But you were faster than me.
    Singh11 and bzinger Thank this.
  7. bzinger
    16,646
    66,144
    Dec 10, 2014
    omaha , ne
    Once in a while I get lucky lol.
    Speed_Drums Thanks this.
  8. Pittstruck
    Pittstruck Light Load Member
    120
    249
    Apr 2, 2014
    Same thing happened to my 2013 about a month ago. Here's the deal. When you run the air conditioner on those freightliners, condensation will form on the sleeper duct work and drip onto the sleeper lighting switches, shorting them out, along with the switches on the dashboard since they are all daisy chained together. This is an OEM design flaw. It also threw a check engine code on mine. If you pull out the switch housing for the 4 way flashers, the wires plugged in the top right corner (black and white if I remember) unplug them and your jakes and all switches in the front will still work and engine light goes out, your switches in the bunk will be unplugged though. Let everything dry out really good and remove your sleeper switches , pull the plugs and coat them with die electric grease, them silicone them up good once plugged back in. Hope this helps save someone money and time!
  9. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    Had the same issue on an old Cascadia I drove for a previous employer. It was the low voltage disconnect and simply starting the truck would reset the breaker.
  10. Singh11
    8
    4
    Oct 6, 2019
    Cascadia doesn't seem to have any fuse box in the sleeper, thank you tho
  11. Singh11
    8
    4
    Oct 6, 2019
    Well thats good to know, I will take a look at that. Thanks
    bzinger Thanks this.
