Slight bends in pushrods 98 w900 n14 cummins
Discussion in 'Kenworth Forum' started by irishluck09, Feb 2, 2026.
  1. irishluck09
    irishluck09 Light Load Member
    292
    177
    Nov 24, 2019
    98 w900 n14 cummins
    Doing an overhaul and while inspecting everything I went and checked the pushrod.
    All of the valve pushrod are fine but all the injector pushrod have a very slight bend in them. A few only have enough space to slide a piece of paper or 2 under it.
    Are they okay to run or should I replace them? Tried to get a few decent pics
    20260202_164840.jpg 20260202_164921.jpg 20260202_164935.jpg 20260202_165000.jpg 20260202_164840.jpg 20260202_164921.jpg 20260202_165000.jpg
  3. Sons Hero
    Sons Hero Road Train Member
    2,994
    30,570
    Jan 8, 2021
    Indiana
    Oxbow and OLDSKOOLERnWV Thank this.
  4. Oldman83
    Oldman83 Heavy Load Member
    838
    10,864
    Sep 5, 2024
    Marrowbone Ky
    If they wobble when you roll them, replace them.
    Drop all the others round end first onto a hard, flat surface and make sure they ring.
    If they thunk, replace them.
    Bean Jr., OLDSKOOLERnWV, Oxbow and 3 others Thank this.
  5. irishluck09
    292
    177
    Nov 24, 2019
    So when I roll them its a very very little wobble. Replace them?
  6. irishluck09
    292
    177
    Nov 24, 2019
    I dont have a problem replacing, just sucks because ill have to wait another week till they arrive lol
    Bean Jr. and OLDSKOOLERnWV Thank this.
  7. Oldman83
    838
    10,864
    Sep 5, 2024
    Marrowbone Ky
    Yes, if they wobble they are compromised.
    Check ALL your pushrods that way, and do the drop test before you order. ;)
    Bean Jr., OLDSKOOLERnWV, Oxbow and 2 others Thank this.
  8. irishluck09
    292
    177
    Nov 24, 2019
    Will do, thank you!
    Bean Jr. Thanks this.
  9. irishluck09
    292
    177
    Nov 24, 2019
    BTW, idk if you ever saw my other post. I had cylinder 6 catastrophically fail. Cummins and kenworth are speculating a failed injector possibly. But I found this broke. Piece in my oil pan and Noone seems to know what it is. About 1x1" cast. Any thoughts?
    W923 Thanks this.
  10. W923
    W923 Road Train Member
    1,419
    4,386
    Feb 28, 2022
    The cast part looks like part of the piston skirt except that it’s not aluminum or doesn’t appear to be…as far as the pushrods I would probably use them…I had a similar deal with one a couple years ago and decided to replace them only to find that the brand new from the Cummins box were not any better….
    I have since rolled most of them from those engines and found very few are perfectly straight. Idk if I’ve just been unlucky or what. I would make sure they have a ring to them as others have mentioned
    Diesel Dave Thanks this.
  11. ElmerFudpucker
    6,930
    75,751
    May 17, 2024
