smoker
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by o1reb, Jul 6, 2021.
  1. o1reb
    o1reb Bobtail Member
    49
    21
    Apr 28, 2012
    bedford
    2013 prostar mx13 trk came in smoking thick black soot no throttle response 2 turbos top high pressure bottom lo pressure is there a way to isolate the bad unit or could it be air control valve
  3. AModelCat
    164,481
    Sounds like EGR valve could be stuck open.
    @Heavyd
    Magoo1968 Thanks this.
  4. o1reb
    49
    21
    Apr 28, 2012
    bedford
    thanks for the info just saved us $4000.00 at least.. the cost of both turbos and the time it takes to pull them
    AModelCat Thanks this.
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Pull the piping and inspecting the turbos is the only real way to check them and pull those pipes is a pain.
    If you have heavy black smoke, then the DPF has failed. If the engine is deleted, then I really can't help further, but at this point you need to run an air management test with Navistar Engine Diagnostics and go from there.
    spsauerland Thanks this.
  6. o1reb
    49
    21
    Apr 28, 2012
    bedford
    it was the egr
    Heavyd Thanks this.
  7. Heavyd
    7,826
    6,276
    Feb 4, 2009
    If you had tail pipe smoke, you still have a failed DPF.
  8. o1reb
    49
    21
    Apr 28, 2012
    bedford
    when the wrench was checking the charge air cooler he left the rubber plug in the outlet pipe started it up got lodged in egr flap didnt notice it drove away hour later the problem happened replaced filter
    Heavyd Thanks this.
