snow on winshield
Discussion in 'Experienced Truckers' Advice' started by aztruckerr, Nov 16, 2013.
  1. aztruckerr
    aztruckerr Light Load Member
    113
    141
    Apr 20, 2013
    phoenix,az
    Ok maybe i'm lazy but question snow removal on your windshield.i told my friend bleach in your bottle he says vinegar
    :biggrin_2558:
  3. snowwy
    snowwy Road Train Member
    20,612
    13,330
    Jul 6, 2009
    i use the plain wiper blade method. for snow removal. :biggrin_25519: flipping on teh bunk heater helps melt the windshield too. since the defroster alone doesn't cut the mustard. unless moving slowly.
    now, if your talking ice. i buy washer fluid that holds to -35. it'll melt the ice and frost. that -20 crap will freeze in them tiny nozzles and then you've got NOTHING.
    never heard of the bleach or vinegar. does that help to melt the snow? or what's the purpose?
    tinytim Thanks this.
  4. G/MAN
    G/MAN Road Train Member
    7,031
    8,625
    Sep 3, 2010
    I would not use bleach. I sometimes pour some alcohol in extremely cold weather, especially with snow and ice.
    snowwy Thanks this.
  5. dooki
    dooki Bobtail Member
    40
    9
    Sep 22, 2013
    NW Arkansas
    my grandpa told me half vinegar half water in a spray bottle will melt the ice. also on another note...come spring mix Mean Green cleaner with washer fluid, knocks them bug guts right off.
  6. FLATBED
    FLATBED Road Train Member
    BLEACH:biggrin_2555: Do you know what that will do to your paint , when the overspray from your washers hits it , VINEGAR is a good glass cleaner but not for snow removal best to use the winter washer fluid.
  7. skibum_63
    skibum_63 Road Train Member
    2,176
    919
    Oct 12, 2007
    somewhere, USA
    I use Prestone De-icer for washer fluid during the winter, and have never had a problem. Carry a small broom, to sweep the major stuff off
  8. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Personally I prefer a LITTLE alcohol mixed w/winter fluid&if u run alot of areas w/heavy Salt application add a drop or two of dish detergent--helps cut the salt--BUT ONLY A DROP IR TWO AT A TIME!! Or it will foam and u will hate yourself&prolly wanna kick me--lol
    062 and luvtotruck Thank this.
  9. 062
    062 Road Train Member
    6,326
    33,966
    Oct 20, 2013
    Mine holds a half gallon,I put half alcohol,half -20, with couple drops of dawn.
  10. 062
    6,326
    33,966
    Oct 20, 2013
    Also don't try to use straight alcohol,it will evaporate to quickly. Don't ask how I know
  11. Mountain Hummingbird
    Mountain Hummingbird Medium Load Member
    601
    399
    Oct 14, 2012
    I use a method as old as the windshield itself it is called a broom. Now you take out the broom you wipe off the snow then you put the broom away. For ice I use what is commonly referred to as an ice scraper it is a piece of plastic attached to a piece of wood. Both can be purchased almost everywhere. For those more technology orientated they have broom with ice scapers already attached.
