So explain 'conestoga'...
Discussion in 'Flatbed Trucking Forum' started by windsmith, Jan 8, 2013.
  1. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    I see many loads posted requiring a 'conestoga' trailer, and with premium rates.
    When I read 'conestoga', I picture 'covered wagon'.
    On the road, I see flatbeds with short stake sides and a domed tarp, and I think 'conestoga'. I also see flatbeds with the 'fast track' or similar tarping systems, and I think the same thing.
    So my questions are: What qualifies as a 'conestoga', and what doesn't? Why would a shipper be looking for a 'conestoga' besides an obvious need for side loading?
  3. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    I see dry vans set up inside for cars tagged as conestoga also. One driver I knew hauled proto type cars for manufactures.
  4. bbmyls2go
    bbmyls2go Medium Load Member
    393
    96
    Feb 19, 2006
    Chattanooga, TN
    you would need to verify that with the shipper in question. Conestoga can either be the vague industry term for a covered flatbed, or it can be a specific request for that rolling track system, the largest of which is, literally branded as Conestoga. I dont see that there is a difference to shippers as long as it is flatbed accessible with a ribbed canvas, not tarped, cover.
    aiwiron Thanks this.
  5. Clasix1055
    Clasix1055 Even when I'm wrong I'm right
    998
    709
    Jan 26, 2012
    Toledo, Ohio
    Conestoga/Fastrack = same thing = rolling tarp system
    side boards with domed top = covered wagon (looks like old stage coach wagon trains)
    both can be side loaded .... ALTHOUGH unless it is an experienced forklift driver you WILL NOT side load my truck because a lot of forklift drivers will bang the rub rails and Fasttrack has an added aluminum rail that will bend then we are screwed
  6. buckeyetrucker
    buckeyetrucker Light Load Member
    157
    254
    Jan 11, 2009
    One big advantage for shippers with the connestoga, is that the tarp will not touch their machines. That is what I hear alot when we go and load at a customer.
    Lepton1 and windsmith Thank this.
  7. special k
    special k Light Load Member
    89
    38
    Sep 6, 2008
    Ontario Canada
    Where I'm at a "conestoga" is referring to a rolling tarp system. In Ontario they often call it a roll-tite. A rack and tarp is referred to by that name or side kit. Sometimes when a customer wants to load/unload from either side and not want to hear the drivers whine about tearing down both sides of their kits:biggrin_25525:they'll specify a conestoga type trailer.
    Steelhauler1246 Thanks this.
  8. Logan76
    Logan76 Crusty In Training
    4,528
    17,698
    Jul 12, 2009
    kittanning, PA
    A covered wagon is not.a Conestoga
  9. fireba11
    fireba11 Heavy Load Member
    864
    541
    Jul 30, 2007
    Tracy City, TN
    Would a curtain side trailer qualify to haul a conestoga load? The only difference would be that it could not be overhead unloaded or loaded.
  10. Clasix1055
    998
    709
    Jan 26, 2012
    Toledo, Ohio
    I dont think so ... Those trailers are weird ... I have only seen them used for hauling cars
  11. Rugerfan
    Rugerfan Road Train Member
    7,681
    39,116
    May 3, 2011
    Redding,CA
    imp retty sure a curtain side is a conestoga isnt it?
