so let's be honest here....
Discussion in 'Experienced Truckers' Advice' started by Gunner75, May 19, 2014.
  1. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    How many of you have unlocked another trucks fifth wheel when that driver was away from his/her truck?
    Why would you do that?
    cbholister and joseph1135 Thank this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,942
    18,949
    Nov 1, 2010
    Burnsville, MN
    Do you really expect someone to say they have?
    Someone might do it if the other driver was being a total jerk in some way, or if a driver was a total jerk and simply wanted to make a bad day for someone else.
    I've never had it happen to me. But, as a Swift driver, I always check.
    SheepDog Thanks this.
  4. 70s_driver
    70s_driver Medium Load Member
    611
    358
    May 4, 2014
    I think anybody that would do that should have his/her CDL revoked and they probably would if they got caught by the man and go to jail to boot. Somebody could be killed as a result of that. I don't rat out truckers but I would if I saw one do that.
    SHO-TYME, Sly Fox, SheepDog and 3 others Thank this.
  5. revenge172
    revenge172 Bobtail Member
    10
    5
    Feb 4, 2014
    Southeast,WI
    I'm going to start with the conspiracy theory. Someone in management followed the driver to give the company a reason to fire the driver. :biggrin_25519: Intended as a joke, but you never know.
  6. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    When I went with Conway Truckload, one of the women in orientation told us she'd pulled 3 locking pins on drivers because they blocked her in a truckstop. She was kind of hardboiled, so I didn't want to argue, but if you pull the pin on a truck that's blocking you, you might not get out for a long, long time, right? Some drivers are like fishermen. It does happen, though, and equipment isn't perfect either. That's why I check my locking jaw every morning at pre-trip time. It is safer, but mostly it makes me feel better about dragging that 53' around all day.
  7. Wallhack
    Wallhack Bobtail Member
    21
    12
    Jan 10, 2014
    Doing 45 In a 70
    My question as well.
  8. Oaker
    Oaker Medium Load Member
    314
    225
    May 29, 2013
    SW Ohio
    It only takes a second to check your 5th wheel... I've made a habit of checking it whenever the tractor been out of sight... over and above PTI's.
    It only takes one knucklehead...!
    SheepDog, zmpart and Oil Jockey Thank this.
  9. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    You know they saying, "every one in prison is innocent". When a driver screws up and did not properly hook up and test for positive lock, and drops a trailer (or high-hooks) ... "somebody pulled my 5th wheel while I was away". I can almost guarantee this is the reality of these situations 90% of the time.
    Edit: In other words, they dropped the trailer somewhere they weren't supposed to (truck stop) and bob tailed somewhere when they shouldn't have (against company policy) and failed to hook back up properly and needed an explanation.
    gpsman Thanks this.
  10. blackcrowntrans
    blackcrowntrans Light Load Member
    133
    73
    May 19, 2014
    I poured kitty litter into the fuel tanks once but the guy diserved it I hated him
    browndawg and TachItUp Thank this.
  11. Flatbedn
    Flatbedn Road Train Member
    1,307
    784
    Nov 12, 2012
    Are you 12?
    joseph1135, SheepDog, Lonesome and 3 others Thank this.
