Specs for otr flatbed
Discussion in 'Flatbed Trucking Forum' started by Soon2BeOwnerOperator, May 27, 2023.
  1. Soon2BeOwnerOperator
    Soon2BeOwnerOperator Light Load Member
    102
    51
    Feb 13, 2019
    New Hampshire
    What is best rear ratio for a 12.7l detroit 60 series with a 13 speed?
  3. Big Road Skateboard
    7,078
    40,104
    May 2, 2021
    OD 13 or direct? 3.70-3.90 depending on target speed with OD, 2.70-2.90 ish direct also depending
  4. Espressolane
    18,652
    116,848
    Depends on what the 13 speed is.
    You have to look at what the combined ratios for the transmission and the differential are. Have run 3:70, 3:55 and 3:42 diffs with a 13 speed transmission. All had slightly different characteristics.
  5. Big Road Skateboard
    7,078
    40,104
    May 2, 2021
    Good points. Expected terrain also changes the equation
  6. beastr123
    beastr123 Road Train Member
    2,947
    24,179
    Jan 2, 2014
    Moose Jaw SK CAN
    In my opinion 3.73 or 3.90 if your planning to load heavy(above 85K) to off pavement points (construction sites etc) or mountainous terrain.
    Between 3.55 and 3.08 if limited off pavement type work or light loads.
  7. Espressolane
    18,652
    116,848
    All a 13 speed is, is a 9 speed overdrive transmission that can split the top gears. Basically overdrive on or off.
