Speed Governer
Discussion in 'Trucks [ Eighteen Wheelers ]' started by budnic, Nov 29, 2009.
  1. budnic
    budnic Bobtail Member
    Hello guys, I drive a 2000 Kenworth C500 winch tractor with a C15 Cat 18, speed Eaton tranny, and a 2 speed spicer A box. The company i drive for has put the clamp done on are rigs and have governed all are trucks at 95 Km/h (55 m/h) i was wondering if there was a way I could get rid of this governer or reprogram my truck to do decent highway speed.
  3. woflpack1967
    woflpack1967 Light Load Member
    93
    18
    Jun 12, 2009
    winston-salem nc
    i would not try it' because if the co finds out about it'you will be filling out a unemplyment claim'because you got fired for messing with the co's trucks'so deal with it.it is not worth it.:biggrin_25513:
  4. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    Yeah , any Cat shop can do it . But it will show up the next time the truck is serviced and that will probably be the end of your job .
  5. Rat
    Rat Road Train Member
    I don't get it, We all know that the company might not like it etc but if the author wants to know how to trick the system then tell the author and let them deal with it themselves.
    I know there are tricks out there to get around the computers and such but people keep so danged tight lipped about it.
  6. Mack427
    Mack427 Medium Load Member
    323
    93
    Jan 22, 2009
    c500 winch truck very heavy specs low gears more than likely walking beam sup. I don't see any real big speed gains possible and not really a truck I would want to run fast even empty, been there done that with a DM SX 58k rears on beam even if the truck would run 65 you couldn't stay in the seat but any desiel shop with cat software should be able to set the road speed up
  7. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    I agree 100%. It's not just here though every forum is that way. If I ask "what's the easiest way to set my truck on fire?" you'll get 100 replys and 99 of them will be someone telling you why you shouldn't do it and one guy will actually answer your question.
    Other than having someone with Caterpillar ET raise the limit in the ECM you could try this http://www.fastertruck.com/. I have no idea if it works just what I found when searching.
  8. TripleSix
    133,081
    bullydogbigrig.com
  9. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Stop in at CAT and ask them about the driver rewards program. They might not help you because you're not the owner. That program won't show up unless they really know what their looking for.
  10. Heavyd
    Heavyd Road Train Member
    7,826
    6,275
    Feb 4, 2009
    If your company has not set a password in the ECM just go to any CAT dealer and have the road speed limit increased to what ever you want.
  11. VARITHMS
    VARITHMS Medium Load Member
    476
    106
    Nov 26, 2009
    HOUSTON
    saftey pass pro, 350$ Its untraceable and removes in about ten min. Google it.
    RickG Thanks this.
