Speedometer/tach glass replacement
Discussion in 'Volvo Forum' started by jayfarmlaw, Mar 12, 2021.
  1. jayfarmlaw
    jayfarmlaw Bobtail Member
    30
    11
    Dec 12, 2020
    it was cracked when I got the truck, but I'm tearing into it this weekend. Any tips or tricks to get to the glass? thanks in advance for your response.
  3. jayfarmlaw
    30
    11
    Dec 12, 2020
    Ended up replacing all three panes with Lexan from Lowes. Less than $10. Pretty straight forward, the only catch is removing the plastic bezel. The factory tabs go into the mounting holes and it looks like they are melted in place like rivets. I had to cut the tops off to seperate. I just used super glue on the tabs to put it back together.
    All in all, a pretty easy job. Now to send it off to have the pins re-soldered so the fuel gauge, blinker indicators, air buzzers, and back lights will work all the time.
    Jay
  4. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    Glad you got it fixed. Lexan will be fine for a while but will eventually get scratched up or discolor
    A local glass shop should be able to cut replacements. When I took my speedo apart to solder the connector back to the board I broke the glass. My local glass shop cut me a new one for $10
