Split Shift Question
Discussion in 'Trucking Industry Regulations' started by MercySakesAlive, Nov 15, 2024.
  1. MercySakesAlive
    MercySakesAlive Light Load Member
    130
    74
    Aug 8, 2008
    seattle ,wa
    Ive never used the split shift rule but I need to tomorrow. In my situation, I want to use the split shift rule to extend my 14-hour work day. But I only want to extend my day using the 7 hour sleeper berth portion of the 7/3 rule. This is what I mean:
    1200am - 300am driving (3 hours total)
    300am - 1000am sleeper berth (7 hours total)
    My question is:
    At 1000am, when I emerge from the sleeper berth, how many hours are left in my work day that began at 1200am? I want it to be 14 hours left to complete my remaining 8 hours of driving. Is this right?
  3. xsetra
    xsetra Road Train Member
    5,195
    7,145
    Aug 21, 2011
    Guessing you start with fresh hours.
    At 10 you can drive 8 hours. Then sleeper for 3hours. Drive for another 3 and sleeper for 7 hours.
    The 2 drive periods can equal 11 hours and your 2 sleeper periods can equal 10 hours.
    You can alternate this pattern until you max your 70 hour rule.
    You won't violate the 14 hour rule. The 14 resets every time you hit the 10 hour sleep period.
    The shorter sleeper period can also be recorded as off duty.
    Using the ELD, I don't remember all the rules sometimes. Your ELD should keep you legal.
    Good luck.
    D.Tibbitt and Oxbow Thank this.
  4. Oxbow
    Oxbow Road Train Member
    13,632
    141,274
    Nov 24, 2015
    Hell I thought this was going to be about a 5 x 4. Dangit.
  5. Blu_Ogre
    Blu_Ogre Road Train Member
    8,454
    50,457
    Jul 14, 2013
    Out west
    Did you complete a 10 hour break before starting up at midnight?
    If so the 14 hour clock would have PAUSED at 11 hours of work shift available and you should have 8 hours of drive and on-duty time available.
    Don't forget to factor in the half hour lunch break in your trip planning.
    Iamoverit and RockinChair Thank this.
  6. 201
    201 Road Train Member
    12,738
    26,198
    Apr 16, 2014
    high plains colorado
    Jeez, and here I was going to explain split shifting,,:(
  7. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,956
    Oct 31, 2023
    You won't have a full 14. You'll need an entire 10/36 to get that back.
  8. MercySakesAlive
    130
    74
    Aug 8, 2008
    seattle ,wa
    Thank you for your help here... I understand how it works now! I appreciate it!
