Sporadic Starting Problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gears, Feb 10, 2010.
  1. Gears
    Gears Trucker Forum STAFF - Gone, But Not Forgotten.
    4,511
    3,185
    Aug 20, 2009
    I noticed when I was in KC last week, on a couple occasions when I turned the key, nothing happened. Turned a couple more times and it fired like normal. Didn't happen for a couple days but the same thing happened a couple days ago. A couple more turns and she started up. Today I had to connect cables as it's real cold and the truck's been sitting. Cranked as normal but didn't start (needed more cable time). Went to start again and nothing. I can hear what appears to be the solenoid click when I turn the key, but beyond that, nothing.
    I'm thinking I need to remove, clean and return all cables going to the starter and solenoid, but am wondering if that will do it or if this this is the beginning of the end of my starter.
    Anyone ever have similar experience?
    (Detroit 60 Series in '00 Freightliner Century)
    By the way... I called Freightliner and they want $600 to replace the starter. That's probably something I could do myself if I could find one....
  3. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I used to have the same issue on a Pete with a C15 that I drove. It would always start on the 2nd or 3rd time I turned the key. Thing is, the truck was totalled (not by me) before the problem was fixed, so sorry I'm not much help. I would guess it would be a connection somewhere though, not the starter.
    Gears Thanks this.
  4. Gears
    4,511
    3,185
    Aug 20, 2009
    That's what I'm hoping, something that accessible too.
  5. RW.
    RW. Heavy Load Member
    715
    995
    Jan 18, 2009
    west central IL
    Cleaning your connections would definitely be the cheapest and simplest place to start. Ours will once in a while do nothing when you turn the key, turn it again and they go. Last winter it started doing it a lot, assumed the starter had developed a dead spot, so we replaced it. Hardly ever does it now. We paid $248 for a reman (12.7 series 60), took an experienced mechanic all of an hour to change it. $600 seems a little high unless they're also charging you for the core, $187. I could do it myself now that I watched it get done, but it would take me longer. :yes2557: Can't remember the size, but you need 12 pt sockets with long extension.
    The Challenger and Gears Thank this.
  6. oneshot
    oneshot Medium Load Member
    626
    248
    Feb 28, 2009
    mississippi
    Gears I know on my old FLD it had a small solenoid on the fire wall above where the steering shaft comes through.Like an old ford pickup.I could cross it to get my starter to work.Dont know if the Century has this but it was about $15 for the FLD.
    Gears Thanks this.
  7. easeway
    easeway Light Load Member
    91
    27
    Dec 28, 2008
    NC
    Gears I have had the same starting issues for the last year but always starts once I turn the key off then back on. KW here w/Cat c15. I have even asked mechanic few months back & reply was possible loose connection, cleaned most I could think of but every once in while still same deal. Let us know what you find out.
    EW
  8. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Yes clean the terminals on the battery and the connections on the starter, but also do the ground connections to the frame from the engine and the batteries. A bad or intermittant ground will give you this symptom, as will a solenoid on it's last legs.
    Gears Thanks this.
  9. Scuba Steve
    Scuba Steve Light Load Member
    176
    146
    Jun 21, 2009
    Chicago IL
    Hey gears, good to see ya, I actually had the same problem on my 96 Dodge Ram Cummins Turbo Diesel, it was the battery cables connection to the batteries (had 2 on the truck). Id clean them real good and the posts real good with a battery cleaning tool, tighten them real good, and most importantly, make sure all of the posts have covers over them and that they arent cracked. If you do this and the problem doesnt happen for a couple weeks or so and then happens again, get new cables, thats what I did when I had your exact problem on my truck and knock on wood but havent happen so far in about a year. Also regardless of what shops tell you about the starter for future refrence 9/10 times the solonoid is what goes bad on the starter, much cheaper than replacing the whole starter. Hope this helps and good luck to ya!!:biggrin_25525:
    Gears Thanks this.
  10. Joew900
    Joew900 Light Load Member
    54
    17
    Nov 23, 2009
    Had the same thing happen to me a few weeks ago,turn the key and all the starter would do is make a clunking sound. The solenoid would engage but the starter would'nt turn. After a couple of tries it would catch and roll the engine over. This happened for several days until it just gave out in New Mexico, checked around and was told the same thing, 6-700 hundred buck for a new starter installed. Got a drag start and waited untill I got home to where I bought the truck and had a new starter installed for $450. Of course I've bought two trucks from them so that might have helped with the price. That clucking or clicking your hearing is the solenoid engaging so you know that it's working but the starter it self is worn out. You can do it your self but make sure you have some help to hold the starter in place while you tighten the bolts. That starter gets real heavy fast when your laying on your back holding it up.
    Gears Thanks this.
  11. Gears
    4,511
    3,185
    Aug 20, 2009
    I started taking everything apart to replace the starter and realized there's a bolt or two that I don't have a clue how to reach. I don't have enough universals to make it happen. Made some calls and found a place that will replace the starter for $450. $150 of that is labor. For that, I'll have it done. Now if I could only figure a way to get the old girl started so I can get it to the shop.....
