Spread axle flatbed
Discussion in 'Questions From New Drivers' started by Buster56, Sep 10, 2018.
  1. Buster56
    Buster56 Bobtail Member
    Greetings and salutations. Question on a spread axle flatbed with a drop down front axle. Should I drop this axle when empty? Obvious increased turning radius when it's up. Have an 800 mile empty and wondering if it will damage tires if I keep the axle down. Any input would be greatly appreciated.
  3. Tb0n3
    Tb0n3 Road Train Member
    4,719
    9,606
    Oct 5, 2012
    Earth
    Leaving it up empty will reduce wear on those tires and reduce rolling resistance for better mileage.
    TripleSix Thanks this.
  4. Nepa3223
    Nepa3223 Bobtail Member
    7
    4
    Jul 25, 2018
    Idk about the trailers but for some tri axles you shouldn’t turn with your tag axle/lift axle down
  5. rockymountainmama911
    rockymountainmama911 Bobtail Member
    19
    Oct 9, 2017
    Can someone tell me..should you lift on sharp turns with a quad axle (nonsteerable lifts) trailer? And do you lower while rolling or do you have to find a place to pull over to lower?
  6. Tb0n3
    4,719
    9,606
    Oct 5, 2012
    Earth
    Depends on permits and towns and how heavy you are. If it's a real sharp turn it's good to do, but certain areas do not allow it. If you're going over 5-10 mph after the corner you probably didn't need to raise them. If you're going slower then drop them while you slowly accelerate.
    I'm no expert, but these are things that make sense to me.
    rockymountainmama911 Thanks this.
  7. Espressolane
    18,524
    115,792
    When empty, keep it raised.
    x1Heavy Thanks this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,142
    Mar 5, 2016
    White County, Arkansas
    Espressolane has it right, if your rig has a "Tag" axle for weight purposes, raise it and keep it raised when empty. It's only to be used when loaded.
    This is not to be confused with trailers equipped with a dump valve. Those like the ones we had emptied the airbags on the aft rear axle of a spread axle so that the tires can "Skip" or float around when you are turning in place as you would be in docking for example. Those tires would still be in some sort of touch with the pavement. The front axle of the spread in this instance would be bearing the entire weight and pivot point in that situation temporarily.
