Spread Axle or Tandem
Discussion in 'Ask An Owner Operator' started by Diligent_Transport, Apr 23, 2022.
  1. Diligent_Transport
    Diligent_Transport Bobtail Member
    49
    51
    Mar 25, 2022
    Looking to buy a flatbed. Will be running team OTR and not sure what would be best.
    I know that Tandem is best for tighter turns and tire wear, and is also a lighter trailer meaning I can carry more weight.
    But spread would be best for smoother ride and handling the weight better.
    Which is actually more common and easier to find as well?
    For the most part, it will be long trips and just going off loadboard loads
  3. Big Road Skateboard
    7,087
    40,161
    May 2, 2021
    Spread with a slider. Saw some 53's in Beatrice, NE I might go look at. They had several if you're looking. 13 models I think
  4. Diligent_Transport
    49
    51
    Mar 25, 2022
    Nice appreciate it, might have to go take a look. 53's seem harder to find right now
  5. Cat sdp
    Cat sdp . .
    21,296
    76,124
    Apr 8, 2012
    Orion's Belt
    48x102 fixed spread with lift and/or dump valve
    welldigger00, Bean Jr., mtoo and 5 others Thank this.
  6. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    X2 on a spread with slide
    Mine is either opened or closed. No in between settings
    It’s a 53’ so closed for light loads and California
    Open for heavy etc
  7. Ruthless
    Ruthless Road Train Member
    9,171
    91,051
    Aug 28, 2010
    The City.
    Closed sliders are heavier than fixed spreads or fixed closed axles.
    Bean Jr., Cat sdp, Brettj3876 and 2 others Thank this.
  8. bad-luck
    bad-luck Road Train Member
    3,429
    6,317
    Nov 16, 2013
    Baltimore, Maryland
    For a flatbed, a spread is best as it is easier to scale out your load. And a sliding spread is optimal.
    merv85, Vampire, GYPSY65 and 2 others Thank this.
  9. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    2 things to think about. A sliding spread is better for weight distribution. A sliding spread can make parking easier, even when heavy. I can't count the times I've closed the tandems to park, especially in tight lots, then spread again when I left in the morning.
  10. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    @Tug Toy I believe has a 53 that can be a closed or open
    Tug Toy Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Unless you have a special need for 53. It's 5 extra wasted feet. And since Tennessee is practically in the way of most loads. It'll have to be closed axle.
    48 spread is the only way to go.
    Rugerfan, Bean Jr. and motocross25 Thank this.
