Spring Bushings
Discussion in 'Trucks [ Eighteen Wheelers ]' started by landstar8891, Aug 11, 2013.
  1. landstar8891
    landstar8891 Road Train Member
    2,414
    2,311
    Feb 4, 2012
    NY NY
    I thought i would try and get more insight on what the machanic told me yesterday..
    My tires in the front are wearing very bad.After further observation he said that my drive ''bushings'' in the back are shot on my old joloppy.He said i should replace all 4,get 2 new steers and have a 3 axle alighnment...
    Does anyone know about how much i should be paying for this job.I just do not want to overpay.?..Is there any other ideas or things i should do while this is all apart..?...
    He also said one of my front baerings are loose.This caught me off gaurd because i just did all the front bearings,front pads and new seals...?..Any ideas would be great...
    I am aware front ends and alignment issues are very expensive.That is why i am hoping to pay one time and not be tossing money at this over and over....
    Thanks for your input...
  3. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Steer tire wear can certainly be caused from everything your mechanic said. As far as cost, we need more detail. Year, model of your truck, and type of suspension. Not every truck is the same. Some brands of suspension are more labor intensive to rebush than others. Just because the bearings in the front were just done means nothing. If there is play, then there is play. You have to be careful when checking. The play can be caused from king pin wear as well. Bearing play vs kingpin play does show movement in different places obviously, so a second person needs to be watching the wheel from the inside to where the play is. The bearings may simply need to be readjusted, no big deal. For rear suspension work I recommend a good spring shop that has all the right tools for pressing in and out bushings. Where it can get expensive is if you go to a shop that doesn't really have the right tools, but can do the job, so they are messing around with hamming out bushings the hard way, taking more time, therefor more money for you. I always recommend to take your truck somewhere, have them look at it and give you a quote. Try to go to a few different places. Trust your gut. If someone rubs you the wrong way with their attitude, or just looks unprofessional, do not use them. Go to the place you are most happy with.
    landstar8891 Thanks this.
  4. landstar8891
    2,414
    2,311
    Feb 4, 2012
    NY NY
    We did the king pins about 6 months ago..We rechecked the kings and they are very tight...We bored them out and put the brass ones in..This appears to be ok...
    My truck is a 1998 freightliner classic.I will have to check and see what type of suspension i have...Yes i should know this but i never lie to anyone,i lack in the whole machanic's of a truck..Been a struggle with this fact for many years...:biggrin_25521:
  5. Boardhauler
    Boardhauler Road Train Member
    1,735
    3,694
    Dec 21, 2008
    Ballin' in it for Shakey
    Alignment issues can be a huge pain. There is so much bad information out there & so many people doing it that don't really know what they're doing. If you want to learn more go to this web page; http://www.mdalign.com/products.html
    Scroll down & check out the book & video. I've bought the book, I think it was about $20 & well worth it. It will teach you do your own alignments at home if you want to, or at least properly diagnose your problems before you go to an alignment shop.
  6. Heavyd
    7,826
    6,276
    Feb 4, 2009
    If you have regular Freightliner air ride type of suspension, bushing replacement isn't that bad. Two basic ways of doing bushings. Unbolt the spring from the hanger on both side and drop the axle down enough for the bushing to clear the hanger and hammer them out. This is can be more labor intensive as most shops do not have a press to push them out with the spring still in chassis, so they hammer them out the old fashion way. Or, bolts and ubolts are cut with a torch, undo the shocks and have the spring on the floor in 10 mins and use a press with the proper bushing driver to press in and out the bushings without the use of the a sledge hammer that may do more damage than good anyway. If your truck has original or really old ubolts, it would be a good idea to install new. Same goes for the drive shocks. This would be a great time to cover all your bases to secure your drive axles from shifting around and bad road contact due to weak shocks. No point in doing bushings to only have old ubolts come loose later down the road. All new hardware and you have nothing to worry about. Then get your alignment, which will go easier because the bushing bolts are new too.
  7. landstar8891
    2,414
    2,311
    Feb 4, 2012
    NY NY
    Here is what was found...
    All spring bushings in back are shot..I am waiting for an estimate...So far i need 2 new steers and they are 700.00 through L/S...
    The machanic is going to take them right out of the truck if he wins the bid..He was thinking about 1,100 for the back...
    Then i will need a 3 axle alignment..300.00
