Spring ride
Discussion in 'Volvo Forum' started by Clay4williams, Jan 18, 2024.
  1. Clay4williams
    Clay4williams Bobtail Member
    19
    4
    Jul 27, 2018
    I'm looking at an old Volvo/white gmc. The truck is very clean. Fits my needs perfect and it's a great price for low mileage. It's an 89 model with an 11.1 in it. Only thing holding me back is that it's spring ride. I've ridden in a few farm trucks that were spring ride (mostly heavy spec international) and they are absolutely awful to spend any time in. This truck was obviously spec'ed as a road truck so I just wanted to see if anyone has any advice on this. Id be using it in a local/regional role. Would it beat the heck outta me? Or is it not too bad once you get used to it?
  3. AModelCat
    164,260
    Spring ride as in 4 spring Reyco or Hendrickson walking beam?
    jamespmack Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    As long as it has an air ride seat, you should be good.
    I drove one with only a spring seat and had to wear a kidney belt.
  5. Clay4williams
    19
    4
    Jul 27, 2018
    Pretty sure it's a reyco.
    That international I mentioned having ridden in has a walking beam.
  6. Clay4williams
    19
    4
    Jul 27, 2018
    That doesn't sound too pleasant lol. It definitely has an air ride seat. I can imagine the seat takes a lot of the hits for you. I wouldn't trade my airride seat for nothing!
  7. AModelCat
    164,260
    Don't know about prices now but 8 years ago I bought a complete cutoff from a wrecking yard for $2500. Not sure on labour as I did all the work myself but it'd probably cost a couple thousand in labour to swap suspensions over if this was a truck that is worth doing it to.
    Bean Jr. Thanks this.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,912
    Mar 15, 2021
    I won’t touch that project for a 1000 dollars I know from experience what it would take to do that more like 3500 or 4000
    I would just get a good Volvo cut off and cut it it in half it would be faster and cheaper caus your gonna have another 1000 or more in parts like axle seats and new U bolts swapping the suspension
    AModelCat Thanks this.
  9. AModelCat
    164,260
    Don't need to disassemble it, just chop the old axles out, roll the brand-used cutoff and suspension under, drill the rails and bolt it up. Did mine myself on a gravel driveway with a pair of come-alongs and a hand drill over a couple days.
    I do agree though, it'd be a cleaner job to just graft the new cutoff onto the truck. I did the swap because I wanted fresh rails from the cab back with no extra holes.
    Last Call Thanks this.
  10. Magoo1968
    Magoo1968 Road Train Member
    2,055
    5,476
    Mar 18, 2021
    St Malo mb
    That Volvo spring ride wouldn’t be too bad on the highway but most likely would suck doing local unless you’re hooked to the same trailer a lot.. city trucks without a air suspension dump are a lot of extra cranking on trailer to match fifth wheel height.
  11. 201
    201 Road Train Member
    12,738
    26,199
    Apr 16, 2014
    high plains colorado
    Your funeral. You'll be tired of it in 15 minutes. The WS in the avatar, an '82 had the Whites version of the Reyco. I'd have to think an '89 W/V/GMC would still have White suspensions. At the time I bought it, I drove almost all spring ride, how bad could it be? It was awful, shook the sleeper to pieces, broke 2 leafs in a month, soon I was calling yards for a Pete cutoff. A local yard/shop had a cabover Pete with airleaf,, cut both frames behind the sleepers, ran a sleeve, bolted and welded, it changed the truck overnight. Depending what you are going to do with it, clearly, an '89 you aren't planning on long haul,,,are you?. Spring might be okay for short trips, dump work, but we've moved on from spring ride for a reason, and to the delight of anyone who spent any time in a spring ride tractor.:hello1:
