sq100 rear ends
Discussion in 'Trucks [ Eighteen Wheelers ]' started by funky dirt hauler, Jan 31, 2009.
  1. funky dirt hauler
    funky dirt hauler Bobtail Member
    9
    San Jose , california
    Anyone out here know about how many miles I can get out of a set of sq100`s ? Truck has had synthetic oils ran in them and they have about 910k on them right now. Any info would really help. thanks
  3. coalhauler625
    coalhauler625 Light Load Member
    96
    12
    Jan 6, 2009
    somewhere in VA,KY or WV
    those 40's are tuff i see guys haling 130,000 0n them all the time but they have easier run's than me less mountains less off-road than what i do ..........as long as temps are good no slack in the yokes just run her ..........they arent to expenseive at all if you decide to pull them i think a bearing kit is around 500 each or so (ballpark) may have to replace axle gears, cross, if you have alot of wear ...........they should last well over a million mile unless you get in a bind somewhere lol
  4. 25(2)+2
    18,759
    45,974
    Sep 18, 2006
    the road less travelled
    The power divider will probably go first. If you have temp gauges that actually work, keep an eye on them, otherwise check temp manually after running awhile, if they are getting hot a failure is coming sooner rather than later.
  5. Brickhauler
    Brickhauler Medium Load Member
    411
    142
    Oct 1, 2008
    Elizabeth CO
    Keep in mind, these are from the days when a 400 was a big motor. I ran SQHD's for a long time with a pretty hot motor and the only problems were the power divider. I did blow the front one up pretty bad once but that was due to a nut backing off inside in the power divider. My uncle ran pretty much the same setup as me and he was pulling his apart every 6-8 months. His driving style was hammer down and hard on the brakes. I never tromped down hard unless I was already rolling. He would always beat me from a dead start but I could catch him on the hills. We used to have a lot of fun truckin'
  6. 1988pete379
    1988pete379 Light Load Member
    193
    75
    Feb 28, 2009
    North East TX
    I have a complete set SQ 100 3:55 's ,Pete airleaf hsg spring hangers wishbones and drive line came out of a 1988 Pete 379 price resonable .
  7. chad
    chad Bobtail Member
    24
    Graham, Texas
    I am in need of a good uncracked airleaf housing front one or price for all you have. Please PM me I dont have enough posts to pm you.
  8. 1988pete379
    193
    75
    Feb 28, 2009
    North East TX
    Chad I sent you a pm let me know if you do not get it Tony
  9. chad
    chad Bobtail Member
    24
    Graham, Texas
