Squeaky front end
Discussion in 'Ask An Owner Operator' started by Paul871, Sep 12, 2023.
  1. Paul871
    Paul871 Bobtail Member
    17
    15
    Jun 5, 2021
    I was wondering if anyone could help me with this squeaky front end. I've got a 2022 W900, and it's got a squeak that sounds like it's coming from my leaf springs. And yes, everything is well-greased. I hear it going down the road sometimes, but always when I go over a speed bump. I read that some guys say it's the hood, but I'm not sure where it would be on the hood. Anyway, maybe someone else has had the same issue and can point me in the right direction.
  3. Long FLD
    Long FLD Road Train Member
    12,726
    53,120
    Mar 4, 2015
    Put rags on the rubber pads where your hood rests and see if it goes away.
    Numb, 201, Phoenix Heavy Haul and 3 others Thank this.
  4. FLHT
    FLHT Road Train Member
    1,423
    2,531
    Aug 2, 2014
    A old pair of socks will work for awhile over the bumpers .
    If thats it your hood bushings are worn out .
    Last Call and Diesel Dave Thank this.
  5. Diesel Dave
    9,516
    31,454
    Jan 20, 2010
    Hesperia, Ca.
    Times 2 on an old pair of socks over all the rubbers. It stop all my squeaks
    Last Call and Long FLD Thank this.
  6. Lazer
    Lazer Road Train Member
    1,837
    2,965
    Jan 22, 2017
    Put the tape over her mouth, guarentee the squeaking will go away.
  7. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Socks are expensive and necessary
    I prefer to borrow a can of White Lithium Grease (preferably from Peelot)
    Spray down bumper stops...coat em well
    Of course return said can to the evil empire
    Rinse and repeat;)
    gentleroger and wore out Thank this.
  8. FLHT
    1,423
    2,531
    Aug 2, 2014
    The guy next to me uses the grease and it works also.
    He is always walking around with a stripe on his shirts.
    Gives his wife something to do ..
    ‘Olhand, Last Call and Diesel Dave Thank this.
  9. gekko1323
    gekko1323 Road Train Member
    1,655
    2,763
    Jul 14, 2018
    Henderson, NV
  10. Cdemars316
    Cdemars316 Heavy Load Member
    929
    5,878
    Nov 10, 2018
    old socks work for me, just had to replace one after two years, found a pair with a hole in them and replaced both of my old socks at once, now she's quiet again
  11. 50WT
    50WT Road Train Member
    2,854
    26,061
    Dec 26, 2015
    I use tire grease or wax or whatever you call it. It's what tire shops use on a little mop to mount tires. I keep some in a small plastic container. It works great, and if you get some on your clothes it'll rinse out.
    Of course you have to reapply after a truck wash. It's call tire soap, just remembered.
