Stacks zero, one, or two??
Discussion in 'Ask An Owner Operator' started by Soonermark, Dec 20, 2019.
  1. Soonermark
    Soonermark Bobtail Member
    35
    40
    Mar 22, 2019
    Someone teach us newbies the advantages and disadvantages of the stacks...
    some trucks have 1 or 2...some have none!
    Some are curved and some are straight up!
    is this all cosmetic? Or is there a benefit of one over another.
  3. Spyro2112
    Spyro2112 Medium Load Member
    622
    432
    Mar 17, 2018
    Duel exhausted, looks, sound,
    Both tubs lead to on exhaust from exhaust manifold
    FlaSwampRat Thanks this.
  4. Spyro2112
    622
    432
    Mar 17, 2018
    Zero is a grass burner
  5. Spyro2112
    622
    432
    Mar 17, 2018
    Underneath the truck
  6. rbrtwbstr
    rbrtwbstr Road Train Member
    3,399
    7,925
    Jul 11, 2012
    in the bush somewhere
    I never understood the mentality behind the weed burner (underneath) exhaust. Seems to me you wouldn't want that unless you had an APU, because of the exhaust blowing out right under the sleeper.
    stillwurkin, mhyn and FlaSwampRat Thank this.
  7. snowwy
    snowwy Road Train Member
    20,609
    13,323
    Jul 6, 2009
    It's one of them latest things for fuel economy. Less exhaust restriction.
    Also less money spent building the exhaust. Cuz the dpf is a hefty added expense alone.
  8. Tb0n3
    Tb0n3 Road Train Member
    4,722
    9,614
    Oct 5, 2012
    Earth
    Lighter.
  9. WHY NOT
    WHY NOT Light Load Member
    160
    117
    Oct 18, 2015
    Why not 6, one for each cylinder. Unless you have a cummins, then you don't need that much exhaust flow, a single 1.5" pipe will be plenty.:)
  10. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Curved vs straight- some are for looks but with a curve or better known as turn out is when sitting not running in the rain water doesn't get in. When water gets in the exhaust will rust out faster and when you start it after sitting in rain it blows black soot water all over your truck.
  11. SmallPackage
    5,765
    18,489
    Dec 20, 2019
    Marion Texas
    Back before all the large cars came standard with duels. 2 stacks usually meant you had a v8 diesel. Under chassis Grass burners were for the gas burners.
    Duels have been optional on the Petes since sometime in the 60’s. The ‘67 in my avatar had a 335 cummins and was special ordered from Fort Worth Peterbilt with them with muffler delete from factory.
