Starter bolt torque
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 2, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    Does anyone know what the starter bolts should actually be torqued at?
    These are the bolts that take a 5/8 12 point socket.
  3. Goodysnap
    Goodysnap Road Train Member
    3,761
    9,165
    Jul 12, 2017
    5/8-11 thread. 159 ftlbs lubed - 212 ftlbs dry. Give or take. Aluminum fly housing I prefer a dab of antisieze or paste as they do lock up with age
    pushbroom, stayinback and Dino soar Thank this.
  4. snowwy
    snowwy Road Train Member
    20,609
    13,323
    Jul 6, 2009
    Tighten em all down so the starter don't fall off. They're pretty big bolts. Tough to over tighten and break.
    Everybody asks about torque. On all bolts in a vehicle. Even the car forums ask.
    I gaurantee. Shops aren't using torque wrenches on every bolt they install. Unless it's the cylinder head.
    D.Tibbitt, AModelCat and Cattleman84 Thank this.
  5. Dino soar
    4,813
    27,058
    Dec 8, 2017
    This is true. But shops that do this work all the time they know about how tight their gun hammers they know about how tight to make this and make that.
    I generally try to torque whatever I can so that I know that it's tight enough and the bolt is not overstretched.
    Sometimes you can't torque it. I can't fit my torque wrench in to torque at least one or two of those starter bolts so I'll do the best that I can.
    But it is a good idea to at least know about what they should be torqued to anyway.
  6. Cattleman84
    Cattleman84 Road Train Member
    10,002
    71,354
    Nov 1, 2017
    The Sticks, Idaho
    German Spec... T.I.T.
    Take it until it breaks, then back it off 1/4 turn... Lol
    D.Tibbitt Thanks this.
  7. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    The bolt won't break but, they are easy to over tighten and pull the threads right out of the aluminum housing they are threaded into. Be careful.
  8. snowwy
    20,609
    13,323
    Jul 6, 2009
    So. Apparently it pays to be a retired mechanic.
    I never worry about torque unless torque is called for. Like shops.
    No break. No stripping of threads.
    We just tighten em down and not worry about it.
    And tighten depends on size of bolts
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    pushbroom Thanks this.
