Starter Problems
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by BRD TRANSPORT, Sep 30, 2019.
  1. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    WHAT DOSE IT MEAN IF JUMP STARTING A ,,STARTER,, THE WIRE YOU USE TO JUMP IT DOSENT WORK AND JUST GETS MELTY HOT.
  3. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    I HAVE REPLACED MY STARTER 3 TIMES IN LAST 4 YEARS AND 2 OF THE REPLACEMENTS WERE DOBE IN LAST 4 MONTHS.
    ANY HELP WOULD BE GREAT.
  4. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    Sounds like what ever you are doing is shorting out the circuit.
  5. Rideandrepair
    17,499
    56,734
    Aug 8, 2015
    Short somewhere. Either in positive wire to batteries or in one of the batteries themselves. Could be the starter, but sounds like you’ve been through so many, somethings shorting out, and burning up starters.Could be the positive wire from starter to the alternater, any positive wire, that’s broken or touching ground, maybe rubbing the frame somewhere.
  6. Ridgeline
    22,694
    121,888
    Bring it to the dealer and have them check the ground and starter.
  7. Dino soar
    Dino soar Road Train Member
    4,813
    27,058
    Dec 8, 2017
    I don't understand what you mean.
    Are you jump starting at the batteries and the jumper cable gets hot? Are you jump starting at the batteries and the starter cable gets hot? Are you jump starting at the starter and the jumper cable gets hot?
    Please clarify.
  8. Freddy2times
    Freddy2times Light Load Member
    64
    31
    Feb 12, 2019
    Very poor connections. Somewhere between 500 and 1000 amps pass through the cables directly from the batteries to the starter.(depends on engine)
  9. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    C-15
  10. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    Jumping at starter
  11. BRD TRANSPORT
    184
    69
    Jul 6, 2018
    Jumping at solenoid pos. to Start ground ?
