starter wires
Discussion in 'Freightliner Forum' started by woodboys, Mar 20, 2015.
  1. woodboys
    woodboys Bobtail Member
    pineville, missouri
    I pulled the starter wires off my starter that are part of the chassis wiring harness from the ECM to the dash and when I reconnected them the truck doesn't start now. It turns over fine just doesn't hit a lick. any clues what could be the problem? It was just 2 wires that went to the double posted hot wire and a small wire that went to I believe a solenoid and then the 2 wires that goes to the solenoid on the firewall. Last time I had the starter replaced it did this and the mechanic did something that made it start but I didn't see what he did.
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You can look inside batt. box for 2 fuse inside small plastic holders, then inside fuse panel at dash,the fuse that runs ecm may have poped?
  4. woodboys
    pineville, missouri
    Checked them all and all are ok.
  5. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    Look carefull for a small wire not put back on starter on power side of tem. on starter sol. what type truck do you have?
