I have a starting issue with a Cascadia, the starter was replaced, I checked the wiring in the Powertrain harness from MCM 21pin connector to starter and thermistor switch in between. By passed that switch at the starter but it is still the same. The starter sounds like ut engages for a second then cuts off internal Sam Cab relay clicks. Also checked wiring from sam cab connector X19 pin 3 to the powertrain harness and its also fine. Anyone got a similar issue? Checked the clutch switch and its also working good.
Starting issue Cascadia 2014
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by A gear per tire, Sep 13, 2021.
