Starting issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Calliph, Aug 21, 2023.
  1. Calliph
    Calliph Bobtail Member
    26
    31
    Apr 17, 2021
    Good evening, My Detroit 60 12.7 will not start. I had to use a jump box at the starter to crank the truck. It wouldn’t crank with the box connected to the batteries. I drove for 8hrs thinking the batteries just needed to charge since it sat a few days.
    Cut the truck off again after my trip and the same thing. Had to jump it again. I notice the volt gauge is reading about 13volts while running.
    I took the batteries to NAPA and had one swapped out.
    used a voltmeter to check alternator and it’s showing 14.5v while running.
    starter is showing 14.5v as well.
    Batteries were showing 12.7 while off and 13.3 while running.
    I changed the Overmolded cable connections over the batteries and cleaned the terminals. Still won’t start without jumping at the starter. Any ideas?
  3. JB7
    JB7 Road Train Member
    1,001
    1,770
    Dec 13, 2022
    Laurel, MD
    Load test all the batteries after disconnecting them. Did NAPA do that? Also load test the alternator. Voltmeter on the alternator does not tell much. Alternator can produce voltage and be weak on amps, especially under load. You don't say if it turns over slowly but not fast enough to start, or if it clicks, or does nothing when you turn the key to try to start.
    Voltage drop test between the batteries and starter.
    Rideandrepair and Oxbow Thank this.
  4. Calliph
    26
    31
    Apr 17, 2021
    Yes, Napa load tested the batteries individually. The batteries are about 8 months old, but one was bad.
    When I try to start the truck It tries to turn over very slowly but stops turning and clicks quickly like the normal sound you hear with a dead battery.
    I didn’t load test the alternator but I will. Is that something they can do at Napa? Would I have been able to drive for 14hrs with the alternator being bad?
    Rideandrepair Thanks this.
  5. 062
    062 Road Train Member
    6,323
    33,959
    Oct 20, 2013
    I’d look at the ground from batteries to frame since you’re able to jump it at starter.
  6. Rideandrepair
    17,534
    56,821
    Aug 8, 2015
    You can drive till you get down below 5 amps. ECM needs minimum of about 3 amps. Something is corroded or loose somewhere. What make Truck is it?
  7. AModelCat
    164,354
    With 14.5 volts at the alternator and starter but only 13.3 volts at the batteries tells me you've most likely got a bad connection between the batteries and starter.
    Run the engine and put one of your voltmeter leads on the starter positive stud and put the other lead at the battery positive post. Whatever you read on the meter is lost voltage. Do the same with the ground. One meter lead on the starter ground strap at the starter if it has one, if not then put it on the starter housing. Other lead to the battery negative post. Whatever voltage you read is lost voltage. Any loss over 0.5 volts on the positive and negative combined is considered unacceptable.
    BoxCarKidd and Rideandrepair Thank this.
  8. Rideandrepair
    17,534
    56,821
    Aug 8, 2015
    Alternator is fine. Cables or ground is the problem. Little wire from alternator may be shorting out, not sending a charge to batteries. On mine it runs to the starter, where it meets up with the 2 hots from battery. You could run a jumper cable from positive battery terminal to positive post on starter. If it works, you know the positive cables bad. Same with grounds. Starter to frame. Battery to frame. Probably have 2 positives running from batteries to starter. One of them may be chafed and rubbing on frame or battery box. Maybe just full of corrosion. What kind of truck is it? Freightliner?
  9. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    Should that 0.5 V drop not be measured while cranking the engine?
    Over O.5 amps on any cable period?
  10. AModelCat
    164,354
    Cranking would be most accurate for sure. With the current draw from the starter that voltage drop will be higher than what you would see from the alternator supplying the amperage to maintain the batteries. I was just thinking it may be difficult for one person to check it while cranking if he didn't have leads he could clip on.
    BoxCarKidd Thanks this.
  11. Diesel Dave Australia
    Diesel Dave Australia Bobtail Member
    17
    5
    Aug 22, 2023
    Jumping at the starter is only 1 wire.
    pretty straightforward job. will isolate any cranking circuit issues.
    or remove the starter and check it on the ground. hard in some trucks… yes.
    but so is not having it running
