Starting issues
Discussion in 'Ask An Owner Operator' started by Adriantx, Aug 15, 2020.
  1. Adriantx
    Adriantx Light Load Member
    64
    17
    Dec 29, 2018
    Replaced starter and had everything checked also replaced all 4 batteries but my question is will a bad crankcase filter make the truck struggle to starting??
  3. marmonman
    marmonman Road Train Member
    1,417
    2,843
    Dec 14, 2009
    central illinois
    Short answer is no
  4. marmonman
    1,417
    2,843
    Dec 14, 2009
    central illinois
    what is it doing ? Slow crank no crank ? Can't help much without a lot more info
  5. Ridgeline
    22,708
    122,513
    CHECK YOUR GROUNDS
    ALL OF THEM.​
  6. Adriantx
    64
    17
    Dec 29, 2018
    Has power i turn key to start and cranks like its will start but stops dose that twice then once I do it the third time it starts had fuel lines battery lines checked put new starter few months ago and new batterys as well dont have any codes or issues with truck once on
  7. Adriantx
    64
    17
    Dec 29, 2018
    Had everything checked fuel lines battery lines and was told nothing was wrong got it hooked up and computer didn't read nothing wrong ethier
  8. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Do you turn the key and let it cycle before continuing to start the truck?
  9. Adriantx
    64
    17
    Dec 29, 2018
    Always let it cycle before starting
    feldsforever Thanks this.
  10. Spyro2112
    Spyro2112 Medium Load Member
    622
    432
    Mar 17, 2018
  11. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Volvo with D13? could be injector cups;
    ops , i just noticed KW in your avatar.
