Steer Axle Brake Adjustment
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, Aug 25, 2017.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    After adjusting front brakes once they're set again they still turn. Is that normal?!
    special-k Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Front brakes is something rarely adjusted. In fact if I remember my manual wrench days long before auto adjuster anything modern, front brakes are deliberately not allowed to "Lock" the two steers up front.
    Without dealing with exactly what you have done or are trying to do to the particular truck, preferably with pictures... I cannot venture to help you further. I would just make a fool of myself.
    JimmyWells Thanks this.
  4. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    I tightened the auto slacks down (just like I would on any other axle) then backed each one off 1/4 turn. After hearing the shoes dragging, I decided to do 1/2 turn. When brakes are set the wheels spin freely though. Just doesn't seem right. They're working fine with the peddle though.
  5. AModelCat
    164,604
    If you're talking about parking brakes on a steer axle they don't exist (at least I have never seen it).
  6. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    I've never noticed this before. Learn something new every day! Thanks.
  7. AModelCat
    164,604
    The chambers on the steer axle should only have 1 airline to each of them. That will be your air supply from the brake pedal valve.
    x1Heavy, daf105paccar and JimmyWells Thank this.
  8. Bigrayon
    Bigrayon Road Train Member
    1,283
    646
    Aug 16, 2015
    As far as my guy that works my truck told me 25 years ago that only the rear the park brake on , infact just last month I had my steer replace on the truck was just the front and yes those bad boys was rolling free
  9. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Thanks for input, gentlemen.
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Standard on FH Volvo's.
    Option on Paccar's EU trucks(Daf).
    AModelCat and JimmyWells Thank this.
  11. cjb logistics
    cjb logistics Heavy Load Member
    766
    643
    Aug 13, 2016
    Liberal Ks
    Steer axles brakes only apply with air pressure, safety feature if you lose air pressure which would cause front to lock up and go into a uncontrollable slide.
    So if you don't no this you should not be working on semi brakes, and probably don't have a certificate.
    Serious business semi brake repairs or adjustments.
    Tb0n3 Thanks this.
