Steer axle crack
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Dorde89, May 8, 2020.
  1. Dorde89
    Dorde89 Bobtail Member
    40
    14
    Aug 5, 2016
    Can somebody tell me what is it ? Hub or ?
  3. Upinsmoke
    Upinsmoke Medium Load Member
    612
    1,206
    Feb 26, 2019
    Just a cap for the hub.
    Not part of the axle assembly.
    stillwurkin and Dorde89 Thank this.
  4. Dorde89
    40
    14
    Aug 5, 2016
    Thanks . What do you think do at TA they have that ? How long i can drive like this ?
  5. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    If it bothers you ( i think it does) it can be replaced but i don't think it does. Doesn't appear to be leaking oil. Speaking of oil, mayby clean around the rubber plug and make sure there is oil in side. Check on the site glass for proper level. If your not sure how to do it..don't. Have someone with experience show you.
    Dorde89 and Upinsmoke Thank this.
  6. AModelCat
    164,515
    Literally a less than 5 minute job to change that. Fill hub back up with oil, let sit a few minutes, top off, repeat until full. Roll around the parking lot, let it settle and make sure its full. Then hit the highway. Check the level again at the next stop.
    Dorde89 Thanks this.
  7. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    its not even leaking. thats the sealing surface. leave it alone. i dont even see a crack
  8. Dorde89
    40
    14
    Aug 5, 2016
    Thanks i changed it at TA. I hope so they did it well.
  9. Chubby Fly
    569
    797
    Nov 25, 2019
    you a new trucker bud? its easy to get worked up over the smallest litlle things if you dont know any better. Eventally you will learn the mechanics of the truck in time
  10. Dorde89
    40
    14
    Aug 5, 2016
    I am driver for 5 years. Owner 4 years. But I didn’t have this problem before. Didn’t want to make any mistake . And I don’t have tools and parts . Thanks
  11. Dorde89
    40
    14
    Aug 5, 2016
