steer tire replacements
Discussion in 'Ask An Owner Operator' started by Semi Disturbed, Apr 4, 2022.
  1. Semi Disturbed
    Semi Disturbed Bobtail Member
    23
    14
    Sep 26, 2021
    Hey some questions here. Would you replace these tires now or give them a few thousands more miles?
    Thinking about going with Yokohama. Any experience with these tires for steers?
  3. Big Road Skateboard
    7,080
    40,122
    May 2, 2021
    Looks like XLEZ. If no cuts to core, run to 4/32 and cap for trailer.
    Looked at all pics. Definitely XLEZ, and appears to have an alignment issue that needs addressed before tires.
    omardten, shooter19802003 and MOBee Thank this.
  4. Semi Disturbed
    23
    14
    Sep 26, 2021
    Yes they are the X-line. Thank you.
  5. rollin coal
    rollin coal Road Train Member
    13,602
    27,963
    Mar 29, 2008
    TN
    For sure need to find out what's going on with your front end or you'll end up ruining another set of steers. For years I balked because of the high upfront price and tried Yokohama, Bridgestone amd Goodyear none of which could make it to 100,000 miles. Finally got a set of Michelin a couple of years ago and they are hands down the best tire I've ever put on the steers. I'll never buy any other tire for my steers.
  6. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Yes change them!! Alignment, shocks keep you air pressure, properly
    MOBee Thanks this.
  7. Semi Disturbed
    23
    14
    Sep 26, 2021
    My next set will be my actual first set I buy. These Michelins were already on here.
    How many miles do you put on your steers now before replacing with the Michelin?
  8. Semi Disturbed
    23
    14
    Sep 26, 2021
    Air pressure has been good 115-120psi.
    Alignment I will do but why change the shocks?
  9. Spyro2112
    623
    433
    Mar 17, 2018
    How old are they?........... now you know
    86scotty Thanks this.
  10. Big Road Skateboard
    7,080
    40,122
    May 2, 2021
    Any premium steer at proper pressure and alignment should run 200k miles.
    Diesel Dave and omardten Thank this.
  11. Semi Disturbed
    23
    14
    Sep 26, 2021
    Don't know they were already on here.
    They will be replaced just will it be now or are these still safe to run down the tread further?
