Steer tires
Discussion in 'Trucks [ Eighteen Wheelers ]' started by shim2000, Apr 21, 2017.
  1. shim2000
    shim2000 Bobtail Member
    24
    Has anyone ever heard of balancing steer tires with rubber inside?? If so can anybody provide information as to whether or not it has been proven to work
  3. Ozdriver
    Ozdriver Heavy Load Member
    770
    1,394
    Oct 16, 2015
    Australia
    Not rubber, but I use a balancing powder called Equal. Works great, but don't get it wet.
    snowman_w900 Thanks this.
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    There are a lot of balancing products on the market. For my steer tires I use Balance Masters and True Balance Centering Sleeves. I have Wide Base Singles on the drives and use Counteract Balancing Beads. I would defiantly recommend at least using balancing beads since its a lot cheaper than Balance Master and will help keep them running smooth.
  5. Accidental Trucker
    Accidental Trucker Road Train Member
    3,437
    7,785
    Jun 4, 2015
    I like the balancing beads better than the balance rings. SMOOTH ride, no funny wear.
  6. rollin coal
    rollin coal Road Train Member
    13,587
    27,944
    Mar 29, 2008
    TN
    I run counteract balance beads in all my tractor tires. They work great very smooth riding and wear. Will be adding them to my trailer tires whenever I put tires on it.
    Cottonmouth85 Thanks this.
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    I have used the Counteract bead product in my drives, but I use Balance Masters on my steers combined with tire spin balance. Just changed out my steer tires that had 232,000 miles on them and still 8-9/32 tread left. No uneven wear. They had started getting a little river wear in a couple of the grooves though. Last set of my wide based drive tires did 447,000 miles with the balancing beads and still had about 8/32 tread left when I changed them out prior to winter about a year and a half ago.
    Auctioneer Thanks this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,548
    6,641
    Aug 26, 2014
    What tire was that?
  9. Cowpie1
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Michelin XZA3+
    BoxCarKidd Thanks this.
  10. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    I have Centramatics on the steers and drive tires and have perfect wear, balance and a smooth ride.
    I believe you can't go wrong with choosing either Balancing Beads or Balance Rings.
  11. earthmover
    earthmover Medium Load Member
    563
    20
    Jan 27, 2009
    castalia , north carolina
    How do you guys think the rings would work on the front of dump trucks ..i run 425 65 22.5 floats ..
