Steering component clicking sound.
Discussion in 'Peterbilt Forum' started by REEFERman450, Apr 22, 2019.
  1. REEFERman450
    REEFERman450 Light Load Member
    191
    63
    May 3, 2016
    2019 peterbilt 579 ultra loft with 55k.
    Making a "clicking" or "popping" type sound when you turn the steering wheel and the engine is running. Sounds like it's coming from the ps pump housing or in that area but I could be wrong.
    Ive also noticed on my pretrip that a set of wire bands on the left front steer tire has also busted causing abnormal tread wear on the 2nd from the inside tread
    I've gotten grease jobs every 15k.
    Thanks for the advice.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Do you own this truck? Can you post a pick of the tire, At 55K you definitely have an issue going on. You may need to jack up the truck when greasing and move the wheel from one side to the other and get all around that kingpin, just keep pumping till nice clean grease comes out the bottom.
  4. REEFERman450
    191
    63
    May 3, 2016
    Yes I own the truck.....its definitely clicking coming from the pump...and here's the drivers side tire.
  5. atvtrailrider
    atvtrailrider Bobtail Member
    7
    Oct 18, 2018
    Did you figure out the issue? I have a 2019 579 with 180,000 miles. No tire issues but seem to have a popping noise coming out of power steering gear box.
  6. P46
    P46 Bobtail Member
    Jun 6, 2022
    Did you ever find what the clicking sound from the pump was?
  7. REEFERman450
    191
    63
    May 3, 2016
    Nope
  8. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    No idea about the clicking sound.
    The tire start cupping.
    I would check the tires balance. On both side actually.
    Today. In a independent competent tire shop, not a truck stop.
    The best check is with the wheel installed on the truck.
    Front axle lifted and the the wheel spun fast with a machine.
    Call ahead some tire shops in the area and find out who can do it like this.
  9. AuntieEM
    AuntieEM Bobtail Member
    I just experienced this. It's most likely the steering gear box going bad. Those are warning noises. You won't be able to steer the truck. I found out on I-90 in Montana. May as well change that and the power steering pump at the same time. They go out pretty much one after the other.
  10. FLHT
    FLHT Road Train Member
    1,429
    2,545
    Aug 2, 2014
    Spring hanger bushings ?
    Don't know if things have changed but steering box was hard to find. Nobody had them.
  11. Mhite
    Mhite Bobtail Member
    5
    May 7, 2025
    Pullman, Michigan
    For the most part I can readily get parts for these but a lot of the time you have to put an em case in as truck down
