Steering input shaft leaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Loaderlou, Oct 4, 2020.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    Hi friends. I have a 2003 Pete 379 with a TRW TAS 65 steering box. The input shaft is leaking. I changed the seal but it’s still leaking. I cleaned the shaft and housing as best I could see. I used a magnifying glass to look in and it looked like I did a good job. I didn’t have the correct tool, j37073, to install the seal, but I took my time with a socket and got it down enough to put the lock ring in. After the install I cleaned again and finished up. I’m still leaking the same amount of fluid as before. Any ideas? Thanks
    Daniel987 Thanks this.
  3. Goodysnap
    Goodysnap Road Train Member
    3,771
    9,195
    Jul 12, 2017
    Time for a reman.......
  4. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Reman,like Goodysnap said.
    You have to much play on the input shaft.
    Nothing you can do.
  5. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    A lot of times it's leaking from plug in the input shaft, not the seal. Regardless, go reman.
  6. xsetra
    xsetra Road Train Member
    5,195
    7,146
    Aug 21, 2011
    When I replaced my 1st steering box.
    The labor was simple and easy.
    However because I didn't read the installation manual.
    I couldn't get it to correctly steer.
    I called parts house.
    Something to do with stops, locks and popets.
    The new box now had a leak. So I put the old one back on.
    Parts house replaced under warranty, they would not replace again. I studied and researched, read what I could find about installing the box.
    I hired the parts house mechanic to do the install
    Good luck
    Rideandrepair and Goodysnap Thank this.
  7. Goodysnap
    3,771
    9,195
    Jul 12, 2017
    Yup, 2 critical steps
    Set the poppets
    And replace the pinch bolt lock nut on the pitman arm and torque it. If you dont it will come loose and ruin the arm and the new gear.
  8. Loaderlou
    342
    131
    Feb 24, 2014
    Thanks for the comeback everyone. I replaced it about 8 years ago. It’s sounds as though that is probably the life span of a steering box. Is there a way to check it further before I do the swap?
    Rideandrepair Thanks this.
  9. Rideandrepair
    17,534
    56,820
    Aug 8, 2015
    I did the seal once on a 68 F 250, same thing, it leaked, bad worm gear I was told.
  10. Loaderlou
    342
    131
    Feb 24, 2014
    Hey Goody. I know you mentioned about setting the poppets. Does the reman have the poppets set or do I have to do that. I don’t remember doing it last time
  11. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Most TRW have auto set poppets. Genuine TRW reman will have directions on installation. Also, their website has service literature free to download.
