Steering problem
Discussion in 'Ask An Owner Operator' started by Taskpimp, Feb 26, 2024.
  1. Taskpimp
    Taskpimp Bobtail Member
    15
    Feb 26, 2024
    I drive a 1998 Volvo sleeper, i replaced both spring leafs, shock absorbers and shackles. And every time I drive in a left curve over 55mph it feels like my truck is gonna flip over, especially in tight left curves even of I am loaded or empty. Any suggestions Where to start from or what can it be the problem?
  3. DUNE-T
    DUNE-T Road Train Member
    7,044
    17,158
    May 10, 2015
    Detroit, MI
    770 or a small sleeper?
  4. Taskpimp
    15
    Feb 26, 2024
    Regular sleeper but low top
  5. Long FLD
    Long FLD Road Train Member
    12,836
    53,717
    Mar 4, 2015
    Is it actually the whole truck leaning or is it just the cab? Cab suspension components could possibly be worn out.
    beastr123 Thanks this.
  6. Taskpimp
    15
    Feb 26, 2024
    The small air bags and the little shock absorbers they old maybe since 1998 lol. You think that can be the problem? Cuz only going tight left curves is the problem
  7. Taskpimp
    15
    Feb 26, 2024
    Is the whole truck
  8. Big Road Skateboard
    7,085
    40,155
    May 2, 2021
    How do you know? Has someone followed you?
  9. Taskpimp
    15
    Feb 26, 2024
    Yes, it was a replied
  10. Long FLD
    12,836
    53,717
    Mar 4, 2015
    If your torque rod at the back of the bunk is worn out it can cause the cab to lean. If the shocks are worn out there won’t be any dampening for your air bags.
    Vampire, Rideandrepair and Diesel Dave Thank this.
  11. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    98-2003 Volvo’s use shocks mounted in a horizontal position to control lateral movement.
    His other issue could be front cab bushings are worn out and need replacing.
    Vampire and Long FLD Thank this.
