Steering wheel at 1oclock
Discussion in 'Ask An Owner Operator' started by Phumac, Feb 20, 2019.
  1. Phumac
    Phumac Light Load Member
    62
    32
    Jun 4, 2014
    i have to the hold the steering wheel at 1oclock to make the truck go straight. Will an alignment fix that? Or is it another issue?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Does the truck pull right or left, or is the wheel just not straight?
    Bean Jr. Thanks this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,143
    Mar 5, 2016
    White County, Arkansas
    Go to the shop let them evaluate that.
    There is a old pretrip back in the days of old iron where when you are sitting still, in park, brakes set you try to move the steering wheel left and right, there should not be more than a certain number of degree of movement of the spokes. If it had too much move in it it failed the front end test and needs to have shop time before you take it out onto the road.
    Now having to hold the wheel at 1, either you are on a high crowned Kansas road, fighting a wind load that requires you to hold a wheel off center to find straight or perhaps your load is shifted and you are trying to keep everything straight even as the rest of it continues to try to fall off your trailer.
    I can say check the pretrips. But reality says people don't do PTI's so... look at the steer tire treads. Any cupping etc. Check the bolts. work your way towards the front end spring ends they should not be broken on any, not have brackets out of place or bolts missing. Your steering fluid lines should not be leaking. And assume there is fluid in your power steering. If you are running off fluid. Check it under the cap.
    Anything bigger falls against your alingment which will find whatever the problem is anywhere in the front end. Your steering column is suspect as well. Your power steering pump may have had a fracture or a pending failure inside the box itself. And you might be in the early stages of that.
    One steer tire might be low on air than the other. Ergo you steer against it or it will pull your rig off road.
    Maybe your trailer started doglegging. So you add a foot this way to make it all straight. But you increasingly get mad. Then mad mad and then detonate.
    77fib77 Thanks this.
  5. Phumac
    62
    32
    Jun 4, 2014
    It pulls to the right. If I hold the steering wheel straight it goes left. Think the steering wheel could be off centered?
  6. Phumac
    62
    32
    Jun 4, 2014
    Most that you said is a negative. Switch trailers all the time with same issue. Check my tire air pressure regularly.
    x1Heavy Thanks this.
  7. 77fib77
    77fib77 Road Train Member
    11,639
    76,731
    Jul 7, 2010
    St Louis
    Is there play in the steering wheel? Has it always been off center? I would take it to an allingment shop.
  8. 201
    201 Road Train Member
    12,763
    26,260
    Apr 16, 2014
    high plains colorado
    It's one thing I could never figure out in all the dozens of trucks I drove, none of them had a centered steering wheel.
    QuietStorm, fss99701 and Bean Jr. Thank this.
  9. 77fib77
    11,639
    76,731
    Jul 7, 2010
    St Louis
    I know you can pull off the steering wheel and re center it.
    stillwurkin Thanks this.
  10. x1Heavy
    34,016
    42,143
    Mar 5, 2016
    I agree with 77fib77 a alingment shop will be able to find it and then fix it.
    Ive had spent sometime in alignment shops like the one out of Baltimore that did a good job on my cabover that was suffering from quite a bit of loose in steering. I think it was about 1500 dollars to get it straightened out. And it did really well. Made all the difference in the world as far we were concerned.
    I actually am trained on alignment of the old manual rack pre-laser days on the older cars from the 60's and 70's which really would not be worth anything in today's alingment shops. I would have to go to school and get certified all over again and that would be a task of itself. We have a good shop here in Searcy that does a good job for the money they charge. Nothing too outrageous.
  11. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Thats because very few alignment techs will recenter the steering wheel after adjusting the front end.
