steering wheel vibration
Discussion in 'Trucks [ Eighteen Wheelers ]' started by razor1983, Jul 15, 2014.
  1. razor1983
    razor1983 Medium Load Member
    500
    509
    Jan 17, 2011
    I get really bad vibration at 45-50 mph, there is some vibration at other speed but what I would consider normal for a freightliner. Right steer tire has a wear on the outside thread. I do have centromatics all around, but I think that tire had a balancing weight that fell off. There is also a vibration at idle, more if the steering wheel is ####ed to a side. And I do get the wheel slop when driving.
    Didnt see anything on visual inspection of the mounts, u joints and u bolts and lug nuts, haven't actually checked the torque.
    Could this be a simple front end alignment balancing problem or the steering box? Or something else?
  3. Lowa3468
    Lowa3468 Heavy Load Member
    889
    648
    Feb 10, 2014
    Portland, Or
    The steer tire isn't set right, which causes the issue, somehow they get unseated or are not seated properly, unfortunately when they go to take it off and try and balance it you will probably be about 20 lbs off which means new steers.
    i had that happen once
  4. razor1983
    500
    509
    Jan 17, 2011
    Yeah as soon as I see wear on the steers I replace them, move them onto the trailer. I was just waiting to find a place to get the alignment done at the same time as well.
    Lowa3468 Thanks this.
  5. razor1983
    500
    509
    Jan 17, 2011
    If that doesn't fix the vibration, I will change out the steering box. Because that steering slop and vibration at idle lead me to believe the gears are bad. Just hoping the rim is not bent.
    I blame the crappy roads in Indiana!!!
  6. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    20 lbs holy cow you must mean ounces
  7. Lowa3468
    889
    648
    Feb 10, 2014
    Portland, Or
    Yes, I did was in a hurry, but the conclusion to the story is that if your tire did unseat and they remove the tire well they won't be able to get the tire back on the rim. Most troubles when vibration starts at around 45-50 but then the vibration seems to go away either below or above that speed generally it's the cause. Just be prepared to buy 1 or 2 new drive tires if they remove them.
    the wear is usually at the bead where the tire sits on the rim and only way to know for sure is to have the tire removed.
  8. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    you said a weight fell off and your using centromatics. you shouldn't have balance weight with centromatics. That will create a shake. worn steering box or loose pitman arm will create slop in the steering. Replace the damaged tire, remove any balance weights if your using centromatics, check wheel bearings and do a alignment.
    SHO-TYME and razor1983 Thank this.
  9. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,180
    Apr 20, 2011
    Dahlonega, GA
    One thing people never think of is dirt inside the rim. It builds up, even if you run mostly pavement and will unbalance a wheel, I clean the insides of my steer rims about once or twice a year.
    Also check, sometimes when people grease the trucks they put a lot of grease in the ends of the tie rods and it bleeds out and drops on the rim, collecting dirt also.
    razor1983 Thanks this.
