I picked up my new to me step last week. I noticed that even having my 5th wheel at the furthest rear position , looks like theres not a lot of clearance when I turn. Much less if I had to slide my 5th up even just a notch for any reason.
Im goint to have my 5th wheel moved back but has anyone else experieneced this?
The truck I bought looks like they moved the sliding 5th forward more to begin with but just curious.
step deck turning clearance ?
Discussion in 'Flatbed Trucking Forum' started by 281ric, Nov 17, 2013.
Actually that seems little out of ordinary considering dry vans normally have more distance from the kingpin to front of trailer.
Normal step deck is 22" kingpin to front. My fontaine is 18" and I've seen some only 12".
The dry vans I pull for UPS is 32"
I actually have to take my drombox/headache rack off to pull their trailers for the winter.
Maybe the previous guy was pulling a step or flat with a 12" kingpin sitting.281ric Thanks this. -
I don't know what you're pulling, but if it's 8 foot top/40 foot bottom, yeah it's going to be like that. They typically have 12" kingpins. Typically a 10' top deck will have a 18" kingpin. The 8/40 Landstar trailer I pulled was SUPER tight with lighted mudflaps with the fifth wheel all the way back.
yes 8' top. looks akward and my concern would be not being able to slide the 5th forward at all
You should not need to slide the fifth wheel at all. With a platform, you position the weight accordingly and a step will also carry majority of the weight on the trailer axles.
I kind of thought the same thing but havent had the pleasure of loading it up yet. Thx
With an 8 foot top deck, he wouldn't be able to slide it anyway. Are you with LS or did you buy a Doonan?
He may not need to slide the 5th wheel forward, but I think he was also questioning the weirdness.
And with a platform, especially 8' top, he should have extra room to slide forward compared to a van trailer. With the setup he's explaining, he wouldn't be able to hook almost anything but a flatbed. -
Get in a big parking lot and make slow partial turns with your trailer. Stop part way into a turn set the bakes get out and look at what kind of clearance you have. Then you are not guessing. If you have a 12" or 18" kingpin then it is going to be close.
rank Thanks this. -
What EXTRA ROOM? A normal trailer would be worse for clearance as the frame rails would be in the normal position and no on the outside of the top deck. View attachment 57650
