Step vs flat for lumber/pipe
Discussion in 'Flatbed Trucking Forum' started by Onewolf81, Jan 15, 2020.
  1. Onewolf81
    Onewolf81 Bobtail Member
    40
    33
    Jan 4, 2020
    Title of the thread says it all...what’s y’all opinion?
  3. npok
    npok Light Load Member
    160
    172
    Sep 26, 2015
    And nothing else?
    The lumber loads I've done are easier to tarp on flats.
    What kind of pipe? Plastic or steel?
  4. Opendeckin
    Opendeckin Medium Load Member
    495
    1,380
    May 20, 2018
    For those commodities enviously a flat. You get a step to haul taller loads and to be able to ground load machinery with ramps.
    You tolerate having to use risers on other loads or not being able to take dock height only loads to have that advantage.
    JonJon78 and clausland Thank this.
  5. Onewolf81
    40
    33
    Jan 4, 2020
    Steel
  6. Onewolf81
    40
    33
    Jan 4, 2020
    Thank y’all for the replies...am considering buying a new/used trailer and have been debating with one of my driver in which one is best. He worked oilfield so he’s used to step and just being loaded by forklift
  7. RollinThunderVet
    RollinThunderVet Heavy Load Member
    717
    970
    Both can be unloaded with forklifts. Standard step like mine can be overinflated to get up to dock height if necessary. Step gives you access to larger stuff. Unless its 41+ ft in length I dont use my levelers, which is not that often. If I get 16ft sections, I place 1 leveler 4 ft back from the drop, everything else goes to the bottom deck.
    Heres the big benefit for me. 3ft to climb on and off is a lot easier than 5 ft.
    Also, it depends on your tractor. If its heavy like mine, then you would be better off with an aluminum flat.
    I've got a w9 studio, and a combo step with ramps that weighs over 14k. I can only take 42-43k on the deck before I break 80 gross.
    x1Heavy and booley Thank this.
  8. Opendeckin
    495
    1,380
    May 20, 2018
    BULL F****NG ####. A standard steps lower deck will be at least 18 inches shorter than a flat. You're not gonna get up 18 inches by just over inflating your bags.
    Brettj3876 and exhausted379 Thank this.
  9. D.Tibbitt
    156,840
    If just hauling general building materies. No need to get a step. U find a step to be a PITA hauling regular freight. In my exerpeience they are harder to get weights evened out . I leave the step to the pros and ill take the flat all day
  10. beastr123
    beastr123 Road Train Member
    2,947
    24,178
    Jan 2, 2014
    Moose Jaw SK CAN
    Most stepdecks are 39 to 44 inches high at the rear bumperif on 255/70/22.5 tires,
    most docks are 48 to 50 inches from the ground because most vans are 48 to 50 inches at the floor.
    A step with a bypass valve can typically rise 7 inches.
    RollinThunderVet Thanks this.
  11. Opendeckin
    495
    1,380
    May 20, 2018
    Dock height is 60 inches...
