Stereo issues
Discussion in 'Peterbilt Forum' started by Phatmat75, Dec 21, 2019.
  1. Phatmat75
    Phatmat75 Bobtail Member
    Put a new Bluetooth stereo in and power only comes on when my running lights are on, is it a harness issue or something like that
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Yes it would be a harness issue, most likely something was miss wired in the jumper harness from the factory plug to the plug for the new radio.
  4. Roberts450
    2,237
    3,636
    Feb 6, 2016
    But first was it a factory radio from peterbilt that you put in or an after market radio??
  5. QUALITYTRUCK
    1,810
    1,775
    Jun 14, 2009
    romulus,mi
    You hooked up your yellow or red wire from stereo to the truck illumination wire. With a test light, you will see that one of those wires will light it up while you are flipping the light switch on and off. Yellow-12 volt battery power. Red- key power. Replacement radios don't need an illumination wire.
    pushbroom and spsauerland Thank this.
  6. RocketScott
    RocketScott Medium Load Member
    579
    948
    Apr 10, 2013
    Kentucky
    Some use the illumination wire to dim the display
