Stick shift
Discussion in 'Questions From New Drivers' started by dboot01, Jul 7, 2023.
  1. dboot01
    dboot01 Light Load Member
    128
    221
    Nov 8, 2021
    Hello, I got my cdl 2 years ago and I was trained on an automatic. I really want to learn stick to open up more job opportunities. 2 questions please:
    Where to get trained on stick?
    Do you need it on your cdl as an endorsement? ( do I need to go to dmv?) Thanks
  3. dptrucker
    dptrucker Road Train Member
    4,701
    3,238
    May 14, 2012
    adelanto,ca.
    you will have to take another drive test at dmv to get the automatic restriction removed.
    its not an endorsement.
    will the company you are at now train you?
    kylefitzy and dboot01 Thank this.
  4. dboot01
    128
    221
    Nov 8, 2021
    Unfortunately no
  5. okiedokie
    okiedokie Road Train Member
    13,697
    108,061
    Jun 13, 2011
    PNWET
    Can you drive a car stick shift?
  6. trips74
    trips74 Medium Load Member
    367
    217
    Nov 7, 2007
    chicagoland, il
    So um probably like 99 percent of the industry is auto now. In fact I don't even think they produce manual transmissions anymore.. if someone is offering you a manual I would run most likely worse then a Chicago 1099 company
  7. AModelCat
    163,726
    They're still making manual transmissions and will be for a loooong time.
    tscottme, Coffey, jason6541 and 12 others Thank this.
  8. MACK E-6
    49,916
    237,094
    I’m sure of that. People like things that actually work reliably.
    Surprisingly I even saw a Turdcadia with a manual today.
  9. AModelCat
    163,726
    Still get Eaton manuals with a Cascadia:
    Oxbow Thanks this.
  10. okiedokie
    13,697
    108,061
    Jun 13, 2011
    PNWET
    Soooo I have a chance to be a trucker.
    Cattleman84 and Oxbow Thank this.
  11. Jenkins2020
    Jenkins2020 Light Load Member
    204
    446
    May 28, 2020
    what? almost all LTL's are still using manuals in their fleet. you absolutely will have to get the restriction removed if you want those jobs.
    Coffey Thanks this.
