Strange cluster backlight and voltage issue
Discussion in 'Volvo Forum' started by Kuldeep, Apr 3, 2015.
  1. Kuldeep
    Kuldeep Bobtail Member
    14
    Jul 3, 2014
    I have 2007 volvo 670 isx. The cluster blacklight goes out and comes back one again suddenly or when there is bump on the road. Also when that happens I see the voltage goes to 24.0 v. Sometimes not always. Also this only happens when truck is cold. Once it's been running on the road its normal.
    Sometimes when the backlight is out. I hit the dashboard it comes on.
    Yesterday I opened all dashboard and fuse box kept moving wires with engine on. Nothin happened everything was normal. After 2 hrs search I put everything back again.
    I checked all connections on battery too seems to be ok. Problem seems to be with ground wire. What should I look for.
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Sounds like a wire is shorting out behind the dash. While the truck is cold pull the dash back and start wiggling wires and maybe you will find it. Or get shocked to death!
  4. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Is everything else working like radio and switches when this happens possible you are loosing can power there is grounds between starter and batteries also between engine block and starter there is a fusible link
  5. Kuldeep
    14
    Jul 3, 2014
    Everything else is fine it's just these two issues I have seen. Everything else works fine. Even the cluster display work and all gauges work. Just the backlight goes dark. I will check on those fuse. I know it something to do with wiring. Cause I was driving thru 60 km wind gust and this started happening. The batteries doesn't not charge to 24v. Cause I stopped the truck and restart they were back at 14.3v
  6. Fidus
    Fidus Bobtail Member
    18
    4
    Jun 17, 2016
    Franklin Park, IL
    Did you ever figure out the problem? I have thesame issue and need help
  7. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    if you have the same problem with voltage spiking up it is the dash assy itself that has a problem and not the truck electrical. impossible to have 24v on a newer semi
    Fidus and KB3MMX Thank this.
