strap clips
Discussion in 'Flatbed Trucking Forum' started by jmlloar, May 10, 2018.
  1. jmlloar
    jmlloar Light Load Member
    100
    13
    Jun 13, 2009
    Keyser, WV
    been out of flat bedding for awhile, what happened to the little spring clips that were in the flat strap hooks that kept tension on straps to keep them from falling off till you pulled them tight, rivited to small hole in flat steel strap hooks? cant seem to find any mention of them when looking at new straps, although the hole is still in the hooks where they used to be.
  3. fargonaz
    fargonaz Road Train Member
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Just loop it around the rail. I've been doing this since the 80's and haven't seen the retainer you speak of.
    stwik and Bean Jr. Thank this.
  4. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Havn't seen those in a while...
    stwik and jmlloar Thank this.
  5. jmlloar
    100
    13
    Jun 13, 2009
    Keyser, WV
    this is actually illegal on a trailer not designed for it.
    the easts we are pulling are not.
  6. jmlloar
    100
    13
    Jun 13, 2009
    Keyser, WV
    I still have a few but was hoping to get more
  7. fargonaz
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Now I'm curious as heck, even broke both my little books out and couldn't find anything. If you have a reference I'd appreciate you passing it along.
    Thanks.
    Bean Jr. and johndeere4020 Thank this.
  8. jmlloar
    100
    13
    Jun 13, 2009
    Keyser, WV
    dont have the exact number but states off top of my head that cant use rub rail as a load securement location unless it has a clearly labeled working load limit on the trailer
  9. jmlloar
    100
    13
    Jun 13, 2009
    Keyser, WV
    wll is whatever is rated lowest, and unless clearly marked like pocket chains ect, a rubrail has 0 wll
    fargonaz Thanks this.
  10. jmlloar
    100
    13
    Jun 13, 2009
    Keyser, WV
    on all 4 corners of this new east trailer
    Bean Jr. and blairandgretchen Thank this.
  11. fargonaz
    1,167
    4,583
    Feb 9, 2015
    Mesa, AZ
    Good to know. The Fontaine that I'm currently using and the Wilson before it have routed openings in an extrusion and the WLL for straps is 5K per the mfg's manual.
