Stryker 655
Discussion in 'CB Radio Forum' started by 715, Feb 16, 2018.
  1. 715
    715 Light Load Member
    95
    72
    Feb 11, 2018
    GA
    Hey Guys & Ladies,
    What power setting do I need to run on this radio? I have it set on 12 o"clock and receive great audio reports. The radio has been tuned and setup by Fine Tune CB Shop. I don't run a amplifier and my antenna is a Wilson 5000 magnetic mount antenna.
  3. Timin770
    Timin770 Road Train Member
    1,657
    1,758
    May 27, 2011
    Canton, GA
    I run the power on my Stryker in consideration of my surroundings and intent. If you are in a crowded truck stop and dont want to blow people away, dial back the power. If you're on the open road you might want to crank it up a bit
  4. 715
    95
    72
    Feb 11, 2018
    GA
    What power setting do you run your's? 12pm, 1pm or etc? Just trying to see where everyone else is running they're Stryker radios at.
  5. Timin770
    1,657
    1,758
    May 27, 2011
    Canton, GA
    I usually run mine about 12 o'clock most of the time and near wide open out on the open road
    715 Thanks this.
  6. 715
    95
    72
    Feb 11, 2018
    GA
    I'll give that a try when I am out on the road to see if I can reach out and talk to someone in skipland on channel 28 or local/down the road.
  7. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    Turn everything all the way up and then go inside and turn the modulation pot all the way up. Then you will be a super-trucker...
  8. 715
    95
    72
    Feb 11, 2018
    GA
    Lol. I'll pass on the going inside of the radio and turning the modulation pot all the way up.
    rabbiporkchop Thanks this.
  9. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    I'd run It Wide Open. Mike gain wide open and RF power wide open.
  10. 715
    95
    72
    Feb 11, 2018
    GA
    I have the mic gain set on twelve o'clock position and running the RF power wide open as I did earlier today and a guy in San Fransisco, California told me I sounded good (Channel 19) and a local also on Channel 19 told me I sounded great. If I run the mic gain all the way up would I sound garble or distorted?
    Also the HIC should I leave it off or turn it on? I have ANL on.
  11. rabbiporkchop
    9,677
    6,526
    Feb 9, 2012
    Wapwallopen, Pa
    The tune on that radio is idiot proof. You can turn the knobs any way you like and you'll never sound distorted or garbled.
