Stuntman with a question
Discussion in 'Experienced Truckers' Advice' started by FallGuy44, Sep 24, 2019.
  1. FallGuy44
    FallGuy44 Bobtail Member
    40
    45
    Sep 1, 2015
    Hello all. I have posted before and the site was very helpful so I'm back. Prior to becoming a stuntman I drove for a living. I have a upcoming stunt for a Showtime TV show in a tractor trailer and wanted to run it by some of you guys.
    So the stunt involves me driving a tanker truck (empty) up a hill. At the top of the hill the driver has a medical issue. The truck proceeds to roll backwards and crash into a bus where it will explode. We will not actually crash, they will just show an explosion over trees as if it actually happened.
    I have no problem in reverse. I haven't seen the hill to know how steep it will be or how fast they want me to go. But I do know at the top of the hill they won't want to see brake lights as I shift into reverse because the driver is supposed to be unconscious. And in case it's a steep hill, I want to be in gear as to not get into a runaway situation. What are your thoughts on getting in reverse when the trucks momentum stops without hitting brakes?
    *I also don't know the type of truck or transmission at this time. It will probably be a standard Eaton fuller etc...
    OLDSKOOLERnWV and truckdriver31 Thank this.
  3. FallGuy44
    40
    45
    Sep 1, 2015
    Lol
    Texas_hwy_287, Oxbow, Lepton1 and 2 others Thank this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Why worry about not hitting the brakes? I'm assuming this is a closed set at that point. Just simply disconnect the brake lights so you can brake all you want. If the show wants to see lights back there, put it on a toggle switch in the cab.
    InTooDeep, Tb0n3, tscottme and 2 others Thank this.
  5. AModelCat
    164,495
    Coast to a stop and slide it into reverse as you start to roll backwards?
    Oxbow, tscottme, Lepton1 and 6 others Thank this.
  6. TripleSix
    133,233
    Decades ago, we used the wire in a kill switch for the brake lights. Came in handy when you needed to brake without attention.
    Oxbow, InTooDeep, tscottme and 6 others Thank this.
  7. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Thats what i was think'in. Unplug the lights, or pull the wire off the stoplight switch. Always kinda dreamed about hooking my brake lights to a toggle switch. Then when one of these tailgating knuckle heads are 6 inches off my tail, flip switch and apply brakes. See if there can do..can keep up with their want to. I know , big trouble if caught pulling that trick. Just a thought.
    InTooDeep, truckdriver31 and TripleSix Thank this.
  8. FallGuy44
    40
    45
    Sep 1, 2015
    Good idea
    Lepton1 and truckdriver31 Thank this.
  9. bzinger
    bzinger Road Train Member
    16,650
    66,161
    Dec 10, 2014
    omaha , ne
    Hey op ! Think you could get Nancy Pelosi on that bus ?
    Oxbow, InTooDeep, tscottme and 19 others Thank this.
  10. FallGuy44
    40
    45
    Sep 1, 2015
    They won't want to see brake lights on camera. But yes, disconnected brake lights seem like a good idea. They may not want that delay however. Sorry if coast to a stop and immediately start backwards. Trying to prepare for every scenario.
    bzinger Thanks this.
  11. FallGuy44
    40
    45
    Sep 1, 2015
    That was my first idea. Just not something I do or did on a daily basis. I'm going to try that in rehearsal.
    OLDSKOOLERnWV Thanks this.
