stupid question about headlight
Discussion in 'Trucking Industry Regulations' started by greenmile_08, Jun 11, 2013.
  1. greenmile_08
    greenmile_08 Light Load Member
    88
    17
    Feb 5, 2013
    eagle bend, mn
    Ok title says it all pretty sure I know but will ask anyway . I have union Pacific 7in round crystal headlights and upon washing my truck today apparently the glass was still hot from when the headlights were on because it cracked it didnt bust or anything but there is a crack is this a ticketable offence light still works fine. Will be replacing but in the meantime was wondering since its functional with no obstruction
  3. joseph1135
    joseph1135 Papa Murphy
    11,340
    27,301
    Nov 8, 2009
    The Highway To Hell.
    I don't think so. It doesn't obstruct your view or anything. If the light is operational then no worries.
  4. Truck-N-Tech
    Truck-N-Tech Medium Load Member
    330
    429
    Sep 13, 2010
    As long as it is 100% functional, and the pattern of light being thrown out front looks normal, you will not get a ticket. The thing is that light could go another week, or another 5 minutes. Better to change it now, on your terms, instead of being out in the rain later, changing it because you put it off.
  5. greenmile_08
    88
    17
    Feb 5, 2013
    eagle bend, mn
    Yea I know ill have it put in 70 $ mistake tho sucks hate to have to scrap it since its fully functional
  6. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,568
    Jul 15, 2006
    El Chuco, Tejas
    They shouldn't have cracked. Headlamps get hot while on but not THAT hot to where cool water will constrict it so fast that it will break.
  7. greenmile_08
    88
    17
    Feb 5, 2013
    eagle bend, mn
    I didnt think so either but I watched it happen it was my dumb$$$ holding the hose. I was washing the fender and the water ran down on to the light and alls I heard was that awful crack sound very bad feeling exp knowing the replacement cost
  8. larry_minn
    larry_minn Light Load Member
    218
    218
    Nov 15, 2012
    Minnesota.
    I don't know this light. Is it a sealed light where when bulb burns out you must reaplace entire unit?? Or is there a "bulb modual" you install in rear of reflector?
    IF it works that to me suggests it is NOT leaking. Air in bulb will normally cause a headlight to burn out in seconds.
    As it has a crack. I would be TEMPTED to get a new light (as soon as I can find once cheap) and keep it in truck. IF the light fails how hard is it to replace on road? As cracked wouldn't most give you a break as it just went? (if they think a rock cracked it thats their assumption. ) :)
    I like to pick up spare parts as they come up. See a similar truck smashed up. Talk to owner and if they are going to let insurance company take it, haul it to bone yard... I ask if I could grab some bulbs. Have spare headlights, one side tail lights/backup/ fuses and wouldn't take a cent for them.
  9. mickeyrat
    mickeyrat Road Train Member
    7,859
    7,542
    Nov 24, 2011
    on my 30 min break
    umm what happens to your lights when it rains?
  10. greenmile_08
    88
    17
    Feb 5, 2013
    eagle bend, mn
    Nothing it doesnt leak just it cracked from to much cold water to fast I imagine ..most rain isnt alot cooler then the outside temp were as the water in the hose was probably 50 degrees cooler then the outside air and id bet 100 degree cooler then the headlight for it to crack ..yes im a dumba%% and yes you can rreplace just the bulb and there is no waiting for a cheaper on there 65 70 a light there the ones with the leds on both sides of the light . I already purchased a replacement although haven't installed it yet I really dont see a need to until mine fails I was just wondering if anyone had a knowledge if I could be ticketed for a crack ..I wouldnt think so because its fully functional and doesnt cause any disruption
  11. larry_minn
    218
    218
    Nov 15, 2012
    Minnesota.
    As far as being ticketed. It does depend if Officer has common sense. (and IQ above room temp) I was driving a pickup and got pulled over. I had a burned out tail light. So I replaced it. (and washed out red lense while it was apart) So she pulls me over because one tail light was "noticeably brighter" then the other. She said "it could cause other drivers to be confused and cause accident....." I dang near laughed in her face. She was serious, had a rider from city council along.. Let me go with a warning. So I loosen the other side/shoot garden hose in and its fine.... What SHOULD happen and what does... I would drive it.
