Stupid question
Discussion in 'Ask An Owner Operator' started by pavrom, Dec 23, 2019.
  1. pavrom
    pavrom Road Train Member
    3,217
    7,421
    Apr 29, 2012
    NE illinois
    How do you guys check if your trailer brake lights are working ? ...i usually drive in the eve and see reflection on the road in the mirror ...
    If one of the pigtails got oxidized and stop light stoped working . If i leave at 9am my parking lot whats the procedure to check my trailer brake lights ?
    ...might sound stupid but it is what it is
    I was thinking about placing weight on brake pedal , secure trolley bar etc ...but honestly i never did it other than checking my tail in the dark
    D.Tibbitt and Cabinover101 Thank this.
  3. RDBG
    RDBG Medium Load Member
    309
    692
    Jun 23, 2016
    You just answered your own question at the end there.
  4. spyder7723
    spyder7723 Road Train Member
    15,471
    25,078
    Mar 31, 2013
    sarasota, fl
    Set your trolley brake or use a stick to hold the brake pedal down. It's not that difficult.
    I used to just use my 4 ways because the turn signals and brake lights use the same circuit. But then I had the brake switch on the pedal go bad and didnt catch it. So don't do that.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    For most trucks just take a bungee cord and hook to the trailer brake and under the driver seat. It will light the brakes up.
    pavrom Thanks this.
  6. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    I'm having an intermittent problem with a turn signal. My left signal on occasion blinks fast as if a bulb is burned out. But I can never find it on a pre-trip. The odd thing is that my trailer signal lights blink at normal speed, but my tractor signal lamps blink fast when it happens. Really an odd one. Maybe just a glitch with the signal relay.
  7. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    1) Ask anyone walking toward your truck to help you out for a second.
    2)Turn your cb on and ask the guy behind you. Believe it or not some of us actually turn it on.
    3) When your sitting in the truck, just ask somebody. Hey I think I have a light out will you check for me.
    4) when standing on the ground ask somebody to push the pedal down for you while you check.
    5) Wedge a stick between the pedal and your seat. Then go check yourself.
    The hey man help me put for a second works best for me. 99 times out of a hundred,
    andhe78, D.Tibbitt and pavrom Thank this.
  8. TankerP
    TankerP Road Train Member
    1,193
    2,751
    Oct 1, 2010
    Holding the steering wheel
    I usually drive to the nearest inspection station and asks the friendly gentlemen behind the desk to see if my brake lights are working.
    SL3406, Sunny90, OldeSkool and 4 others Thank this.
  9. pavrom
    3,217
    7,421
    Apr 29, 2012
    NE illinois
    Can friendly gentleman put you oos if its not working !? :)
    D.Tibbitt, PE_T and Badmon Thank this.
  10. Badmon
    Badmon Heavy Load Member
    806
    1,503
    Oct 6, 2014
    Deep south
    This is genius
    D.Tibbitt and Bean Jr. Thank this.
  11. Dino soar
    Dino soar Road Train Member
    4,815
    27,071
    Dec 8, 2017
    I have a piece of steel tube cut to the right length that I can wedge between the seat and the brake pedal.
    But a broomstick handle or 2x4 or whatever you have will work.
    pavrom Thanks this.
