Stupid Question
Discussion in 'CB Radio Forum' started by rainmakerr, Aug 30, 2013.
  1. rainmakerr
    rainmakerr Light Load Member
    100
    25
    Mar 15, 2012
    Centreville, AL
    So I did a search on the internet with no luck, tried to look on here with same results, so let me ask a stupid question; what is the difference between the standard cb and a "big" cb?
    mp4694330 Thanks this.
  3. Ridgeline
    22,700
    122,088
    One has all kinds of "toys" on it while the other doesn't.
    A lot of times the BIG CB is made as an Export Radio, which is really a claim to be a 10 meter radio and has really broad receive and transmit but comparing it to say a plain Cobra 29, even a 23 channel version, it is about the same.
  4. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    Well, it's sort of a loaded question....but so it seems, what is referred to as a "big CB" is something like a Connex, General Lee or any of the two digit series Galaxys. You can also consider Stryker, Superstar, Northstar, RCI and Magnums as big radios as well.
    So what makes them big CB's? Well first off in reality they're not true CB's, but rather "export 10 meter radios", designed to be "converted" to CB, to circumvent the FCC's rules of "no more than 40 channels/frequencies, and no more than 4 watts of transmitter power, tops".
    Now....my guess is the reason they're considered "big" is because they in fact do have more than 4 watts of power, and have more than 40 channels, is what gives them the "big" impression. It could be also because some of them come factory with echo and roger beep. Also many of these radios are in a full sized chassis. A few, such as the Magnum 257HP are in a chassis smaller than a Cobra 25, yet pack a 15 watt deadkey/80 watt swing, with SSB and the ability to cover several channels/frequencies, from 25 MHz to 29 MHz.
    But alas, how thee can be easily fooled. I have installed echo boards and roger beeps into mainstream 40 channel radios such as Unidens and Cobras and have had people thinking I was on a "big" radio, even if I was only packing a 4 watt deadkey/12 watt swing punch.
    On the flip side, most Cobras, most Unidens, all Midlands and all three digit Galaxys, are considered your typical CB, as they're certified CB's courtesy of the FCC. Cobra does have two models (DX 150 and DX 200) and Uniden has their HR 2510. Neither the Cobra DX 150/200 nor the Uniden HR 2510 are FCC certified as they exceed the 4 watt/40 channel rule...some may consider to be big radios.
    Anyways that is my take on it.
    Flying Dutchman and mp4694330 Thank this.
  5. poppapump1332
    poppapump1332 Road Train Member
    2,987
    2,465
    Jan 2, 2010
    birdsboro,pa
    Idk I've seen cobra 25s that I'd consider a big radio as a matter of fact most use them in keydown comps.a big radio is one that's loud and gets out usually with the help of a linear doesn't matter what the make is export or not.
  6. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    Thanks for all of your input, I was wondering about this; now I know.
  7. mike5511
    mike5511 Road Train Member
    3,155
    1,546
    May 15, 2011
    NW Arkansas
    That was not a stupid question. And you got good answers.
  8. rollingradios
    rollingradios Light Load Member
    184
    66
    Mar 9, 2012
    Richmond, Va
    So many opinions you will hear as you log more time on CB.
    Typically, loud, echo, strong.
    My thing is accurate voice reproduction and clarity while having the most volume. Not many people have an ear for that.
  9. 6string
    6string Bobtail Member
    49
    13
    Mar 24, 2013
    most people consider the export radios big ones but when your talking to someone a cobra 29 with the
    final changed to a 1969 final or a 520 plus the caps and resisters you have to change and it sounds loud
    with the watts and adding echo board
    if its clipped i consider that charlie brownish
  10. Guvhog
    Guvhog Light Load Member
    69
    10
    Aug 9, 2013
    Pine Bluff, Arkansas
    If you're going to use a Linear with a cobra 29 you can have the dead key output lowered to 2 watts and have your modulation turned up so you have a swing output of 8-12 watts. It is LOUD like a BIG radio. I've received numerous compliments on how loud and clear my Cobra 29 is.
  11. rainmakerr
    100
    25
    Mar 15, 2012
    Centreville, AL
    Would it be worth the money to buy one of these Big CB's? I assume that a Galaxy DX 959 is NOT a "Big" CB
