Stupid question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Overhaulin, Apr 20, 2024.
  1. Overhaulin
    Overhaulin Bobtail Member
    20
    10
    Aug 2, 2016
    I went out today to cage the brakes on a truck I recently purchased that has not moved in several years. It has a Detroit with several injectors stuck so I can't fire it up to release the brakes. I tried to use the cage brake bolt and while I can place it in the keyhole I cannot turn it to lock it inplace in either brake chamber.
    Any suggestions?
  3. FLHT
    FLHT Road Train Member
    1,424
    2,532
    Aug 2, 2014
    Back off the slack adjusters..
  4. roundhouse
    roundhouse Road Train Member
    3,207
    7,314
    Jul 11, 2018
    You can also use a air line to the system on the truck and charge up the system if it doesn’t have any major leaks
    use a portable air compressor or another truck to suplly the air.
    skallagrime Thanks this.
  5. 201
    201 Road Train Member
    12,722
    26,163
    Apr 16, 2014
    high plains colorado
    Sounds like crud in the chamber, especially if those covers gone missing. The bolt isn't going in far enough to turn, maybe some "knocker loose", or a rap with a hammer or disconnect the actuating arm. Still waiting for the stupid question,,just kidding, there are no stupid questions, not here anyway.:thumbup:.
  6. MRMTRANS
    MRMTRANS Medium Load Member
    406
    440
    Apr 28, 2015
    Like Roundhouse said, try filling up the tanks from another aur compressor. Take a plug off an air tank and put a female quick connect airline fitting for access to charge. Or you can charge from at the teflon lined line between the air compressor and drier.
  7. Inderjit
    Inderjit Heavy Load Member
    767
    729
    Sep 17, 2017
    Lube the threads on the release bolts and use a long handled ratchet. It takes lot of pressure to release them.
  8. skallagrime
    skallagrime Road Train Member
    3,854
    9,926
    Apr 10, 2012
    Indiana
    This is the way
  9. Nine_Lives
    Nine_Lives Bobtail Member
    22
    20
    Apr 20, 2024
    If it's been long enough after you get it aired up and the valve pressed make sure the shoes aren't rusted to the drums. If it's dirt blown in the cans that's keeping your cage bolt from locking in you can try blowing them out with your air, then cage em after they're released so you don't have to deal with losing air every so often.
  10. Allhookedup
    Allhookedup Bobtail Member
    7
    Apr 24, 2024
    Air it up and save some wrenching on the cage bolt
    AModelCat Thanks this.
