Did an oil change Sunday on a 3126 Cat. in a Freightliner M2 106
and found 1/4" piece of piston ring on the magnetic plug.
Brand new short block w/ 30,000 miles.
Wouldn't this eat the cyl. bore? And the side of the piston?
What do I do?
SURPRISE!!
Discussion in 'Freightliner Forum' started by rolls canardly, Apr 17, 2018.
The broke pieces may have came with the short block,
If there is room you can pull injectors and look inside with a scope before you pull the head. -
Short block was not a Reman. - w/undersize journals, undercut crank, etc.
It was a brand new crank, and a new block, right from Cat - for 7 grand.
Yes; true, good Idea w/ the scope.
They have scopes now that are super small dia. on Amazon, they go to your phone to view.
May end up buying one just for this. -
You have got to get rid of that truck...
It’s Evil... -
Its time for a new engine rebuild/ replacement
It was just getting in the way. the motor will run much better without it.
I know; its them new automatic self-gapping rings.
I don't see how this piece of ring could possibly slide it's way out
without making a "compression loss highway" - right into the oil pan.
No pressure there??
No power loss??
I'm about to cut open the filter - and look for the loch ness monster or sasquatch in there.
Must be somthin in there, I notice my oil pressure went up.Streetroddreams and Klleetrucking Thank this. -
so I just cut open the filter. Nothing.
Black goo, some metal filings stuck to a magnet,
but not even the size of a pencil eraser came from the whole filter.
Could someone have dropped that in there to bust up stuff? -
I drove it again today about 150 miles.
No issues with power, smoke, noises.
Nothing.
OK; that's a good thing.
Never mind, and thanx all - again. -
I broke a injector years ago, it was almost 2 years before the broke screws came out on the oil plug.
A broken piece in a oil passage way wouldn’t be a first for cat. Think lazy union workers.
