Swift Trailer Question
Discussion in 'Swift' started by Grumppy, Aug 27, 2019.
  1. Grumppy
    3,218
    11,338
    Dec 11, 2010
    West Monroe, La
    Over the past few months, I have had the need to hook to a Swift trailer.
    What is Swifts idea behind spec-ing their trailers with the dolly handle on the right/passenger side of the trailer?
    I guess with all of Swifts intelligence, there is a reason for it, but for me, not being a Swift driver, this is odd & totally .......... well, never mind, I just wonder why they put the jack/dolly handle on the wrong side.
    D.Tibbitt and FlaSwampRat Thank this.
  3. crazy8rob
    crazy8rob Bobtail Member
    12
    6
    Sep 7, 2008
    Burton, MI
    I'ts the manufacturer who makes the trailer not swift, as why on the right side I haven't a clue
  4. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Until recently, Swift also spec'd their company trucks and lease purchase trucks with the fifth wheel release handle on the right hand side.
    The reason they spec'd the trailer landing gear handle on the right side is most lazy drivers didn't put the handle back down so it's not sticking out after they dollied down, so it prevents a bent landing gear handle.
    Since most backing of trailers is done on the sight side, there's a greater chance if the landing gear handle was on the left side that it would be bent if it was sticking out because it couldn't be seen as easily as if it was on the sight side.
    Also if you needed to drop the trailer curbside or roadside you wouldn't be exposed or a target to passing traffic.
    Bakerman Thanks this.
  5. buddyd157
    buddyd157 Road Train Member
    13,582
    34,899
    May 25, 2017
    under a shade tree
    because being a Swift driver, it'll only add to the personal injury, of him getting clipped by a passing vehicle, even a 5 year old on a "big wheel"....
    on the passenger side, that lessens those odds by about 75%....since about only 25% of the "Big wheelers" still drive on the side walk...
    Dave_in_AZ and FlaSwampRat Thank this.
  6. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    159
    265
    Jun 24, 2017
    Forces the driver to actually look at the passenger side of the trailer. Dont see many drivers doing pretrips anymore.
  7. Atlanta trucker
    Atlanta trucker Road Train Member
    1,605
    2,003
    Jan 25, 2017
    Some people don’t think much.
  8. Grumppy
    3,218
    11,338
    Dec 11, 2010
    West Monroe, La
    This was my thought, but honestly, I had no clue as to the real reason.
    Thanks for the replies.
  9. Moosetek13
    Moosetek13 Road Train Member
    14,924
    18,917
    Nov 1, 2010
    Burnsville, MN
    The right side is, the right side.
    You lower the landing gear and pull the fifth wheel on the same side.
  10. gentleroger
    gentleroger Road Train Member
    7,840
    21,376
    Jun 1, 2010
    But the customet specs it out. There are limitations, but putting the handle on the passanger side is a choice.
    I always assumed it was to encourage drivers to walk all the way around and posttrip before dropping.
    Another reason could be the landing gear they are using. For the Holland landing gear on a dry van or reefer if you put the crank handle on the driver's side out is high range and in is low. If you put it on the passanger side, in would be high range. So ergonomically the passanger side would be better.
  11. Tolmie
    Tolmie Medium Load Member
    362
    256
    Dec 22, 2017
    I thought it was because Swift wants to do everything contrary to others.
    Cat sdp and D.Tibbitt Thank this.
